Results 1 to 3 of 3
    Account Terminated Four Rings
    Oct 28 2006
    GT30r'd A4 on Meth, 01 Durango
    New Issue: Keep Blowing the Engine Timing Fuse
    like the title says I keep blowing the engine timing fuse everytime i go to start my car. When it blows the car just turns off. What wires run to this fuse and does anyone have a wiring diagram
    Feb 27 2005
    North Wales, PA
    Re: New Issue: Keep Blowing the Engine Timing Fuse
    use vag-com to find out which sensors are getting the short to ground codes. Then one by one plug one until you find the culprit. If you engine will run long enough maybe you can get a code for a bad sensor before the fuse goes. I'm betting a shot evap purge valve. It happened on my car and i just left it unplugged for a while. I wa gonng fix it, but my car got hit.
    Oct 28 2006
    Quote Originally Posted by Poopie View Post
    i vaged it and got got short to ground codes for the evap system, n75, purge valve, thottle sensor, cam position sensor, bank 1 sensor 1 malfuction, bank 1 sensor 2 malfunction, bank 1 sensor 1 (lambada) no activity, bank 1 sensor 2 (lambada) no activity. When i clear them the only ones that stay are the evap, purge and n75 codes. i tried unpluging them and starting the car but had no luck
