Results 1 to 7 of 7
    Veteran Member Four Rings jackyaudi's Avatar
    Jun 26 2007
    '02 A4 1.8TQS
    Montreal
    Help removing shift knob and ebrake cover
    I would like to know how to remove the shift knob (automatic) and the ebrake's plastic cover, any instructions (with pics if possible) will be appreciated!
    For your OEM HID D1S/D2S/D3S and HID conversion [Headlights/Foglights], and Interior/Exterior LED needs, send me a PM.
    Stuff F.S: http://www.audizine.com/classifieds/...4-parts&cat=21
    Jun 11 2008
    Williamsport, Pa
    Re: Help removing shift knob and ebrake cover
    theres a thread for b7 console in b6. i think that would be partially what you need. it requires you to remove the radio and heat controls. not sure about the knob though.
    http://www.audizine.com/forum/showth...hlight=console
    Veteran Member Four Rings Charlescrs6's Avatar
    Sep 28 2008
    Boston, MA
    ask maverick, he's done it
    Current: ISO RS4
    Past: E46 M3 Convertible 6MT, B6 A4 1.8TQM Ultrasport, B6 A4 3.0Q
    Jun 26 2007
    '02 A4 1.8TQS
    Montreal
    ^^ thanks. I asked him, he actually removed the whole ebrake, but not sure about the cover.
    Anyone else?
    Veteran Member Four Rings jon102034050's Avatar
    Oct 02 2006
    MN
    http://www.audizine.com/forum/showth...ifter+searched
    I got half of it done for you. Just watch out, i almost hit myself in the face when i took mine off, its really stuck on there tight.
    A4 1.8TQ - RS4 Sway - Avic-D1 - Neuspeed Sports - Bilstein Sports - Joey Mod
    Jun 26 2007
    '02 A4 1.8TQS
    Montreal
    ^^ thanks, I actually ended up peeling the button down to its black color and cleaned it. It looks much nicer now, so no need to remove anything in that area anymore.
    Am still stuck on the ebrake's plastic cover though....
    Veteran Member Four Rings AudiA4Style's Avatar
    Feb 24 2004
    B8.5 S4 l 75 CB550 Cafe Racer
    the ebrake is a bitch, took me a while to get it out.
    Are you replacing it with another oem cover? If so, you can see where the piece is hooked. Get a flat head screw driver and push the ebrake hook up (IIRC) from under the ebrake and try to slide it out. A little wiggle while youre doing this will help.
    Good luck!
