Results 1 to 7 of 7
    Established Member Two Rings tj19855's Avatar
    Jun 30 2008
    2003 Audi A4 Quattro 3.0 (B6)
    Houston, TX
    Question Cylinder Misfires
    Started the car today, it was cold outside, It started having multiple cylinder misfires when on idle, CEL started blinking, car started to shake so I drove it anyway, What could be causing it? I did replace the ignition coils a few months back and the spark plugs. Now my Oxygen sensors are bad could this be causing the misfires?. Looks like every time it gets could outside my car starts acting up.
    2003 A4 Quattro 3.0 UltraSport Suspension. Magnaflow Mufflers, K&N Air Filter, 19" Wheels 2" Lip 235-45-19 GE UHP.
    http://www.youtube.com/watch?v=9r0i41zVUw0
    Veteran Member Four Rings CO AVANT's Avatar
    Feb 12 2004
    '03 B6 Avant, '15 B8 A4, '14 S8, '15 Duramax
    Everywhere
    Re: Cylinder Misfires
    Did you put colder plugs in last time around? Bad O2 sensors could be messing things up too. How many miles do you have on the motor? Did the blinking CEL go away once the car was warmed up? I have cold start misfires when using cold plugs. Goes away once warmed up for a bit...
    Jun 30 2008
    Houston, TX
    106,500 miles on the car, I dont know what kind of plugs I have the shop I took it to probably put cheap ones on. Yes the blinking CEL went away after it warmed up. Last time I did a Vag-Com reading I had mostly all cylinder misfires, oxygen sensors and catalytic converters not working.
    Feb 12 2004
    Everywhere
    throwing any codes?
    Veteran Member Three Rings PCYC's Avatar
    Sep 07 2007
    04 A4 3.0 6spd, 06 A6
    Atlanta GA
    my car does this to the dealer said it was fine. And I have intermittent fires in cyl 5. weird could be one of the 5 v per head haha
    Veteran Member Four Rings Boosted3.0's Avatar
    Jul 27 2008
    02 A4 3.0, 08 M5 5.0
    Miami, FL
    Sad to say but this is pretty normal. 3.0's run lean on start-up, not really damaging but just really annoying. The shaking car part...not so normal that seems like it could be more then a misfire.
    High speed Ferrari movement...
    Jun 30 2008
    Houston, TX
    One of my plastic tube broke and was lossing air pressure, so thats why it was misfiring cost $400.
