Results 1 to 7 of 7
    Veteran Member Three Rings Unispeed's Avatar
    Feb 22 2007
    Earth
    Bailey BPVs... are you sure they are not leaking??
    I happened to have some extra time on my hands last night and decided to regrease the bypass valves I have ( Bailey). So, I go to unscrew the plastic hose barbs and find out that one of them is cracked....so I thought to myself..no biggie.. Ill just thread in there a brass hose barb.....NOPE, a 1/8" hosebarb starts but doesnt go past the first thread... Nobody I knew of carried metric hose barbs so I tapped it, cleaned it.. and now it has a brass hose barb.. the way it should have come from Bailey!!!! Ok, I'm done with the venting... its just insane that you pay 150 a piece for those things and they wont spend an extra couple of dollars for brass! Not only that.. they make it so if you wanna go with a standard brass hose barb you have to tap it...
    2015 Audi A4 2.0TFSI (GEN 3 engine) with DL501 transmission (GEN 2 tran.)
    (B9 A4 engine mated to an S4 transmission in a B8.5 chassis. )
    2000 S4 6spd stg 2+ (gone but not forgotten)
    Veteran Member Three Rings TheDarkness's Avatar
    Jul 13 2008
    15' A3 2.0T , b5 S4 Stage III
    Re: Bailey BPVs... are you sure they are not leaking??
    I have those, installed when I purchased the car. They def. have a loud "psshh" sound like a bov in between shifts, with these guys...does that mean they aren't functioning properly and leaking? I hold boost pressure great at 18 peak and 15 hold tho.
    2001 Stage III Pearl White B5 S4: Frankenturbo F21s | Iforged Flux | Solo Motorsports Dyno Tune | Bosch EV14 52#
    2015 A3 2.0T 8V Mythos Black: KW V3s
    Feb 22 2007
    Earth
    Quote Originally Posted by TheDarkness View Post
    Note that in my case it was not the valve itself that is bad, and honestly.. the piston design is top notch (piston with rubber o ring to seal instead of a brass piston like some companies do). My problem was with the plastic nipples. One of them was cracked and thats where one of my leaks was.
    Veteran Member Three Rings SilverBiturboS4's Avatar
    Sep 14 2006
    Dallas,tx
    Quote Originally Posted by Unispeed View Post
    The Ones i had before i switch over to the forge DVs had a Brass Barbs.
    2001.5 S4
    Jul 13 2008
    you said nipple.
    Feb 22 2007
    Earth
    wow... ok, for you we'll call it a hose barb... ohh boy! lol
    you said nipple.
    Veteran Member Three Rings s42k5b's Avatar
    May 31 2008
    New York
    Thats the sound my dv's made when the nipple was cracked on them.I would assume they are not functioning properly.I Ended up replacing mine with 710n's, i didnt feel like spending 300 plus on baileys, forge etc..
    00' Cactus, GIAC,H&R coilovers,original K03's for the time being..
