Results 1 to 24 of 24
    Established Member Two Rings jaredsogn's Avatar
    Oct 02 2006
    2001 Silver S4
    Watertown SD
    Throttle cut/boost issue...
    Hey guys, posted about this the other day, trying to gather some info. I have 997/K04 hybrids I just put in. Turbos are spiking to about 24 PSI, then dropping to 10 or 15, back up to 24, down to 10 or 15, back up...etc. It seems like the car runs strong every once in a while for about the first pull I do, then it runs poorly like this. Anyone have ideas of what to check, what could be wrong? I pressure tested and didn't find any leaks. Any suggestions are welcome, and please let me know what you think about the logs, does the N75 duty cycle look normal?
    Log of throttle angle when it seemed to run ok:
    And the rest of the logs are when it was running poorly, cutting throttle, etc...
    Oct 31 2005
    Ashburn
    Re: Throttle cut/boost issue...
    I can't be much help, but to better assist you with your issue's it would be good to list all supporting mods to the car.
    - Instagram: @Sinister_rs5-
    Oct 02 2006
    2001 Silver S4
    Watertown SD
    Mods done to car are:
    Darintake
    Piggie Pipes
    997/K04 hybrids
    10secs4 fueling
    Stock exhaust with resonator removed
    Veteran Member Four Rings haus4's Avatar
    Apr 27 2008
    silver s4
    LI
    there is definitely something wrong with the throttle response. either gas pedal is messed up or something related to your tune. Btw, wat tune are you running?
    Oct 02 2006
    2001 Silver S4
    Watertown SD
    Well, my thoughts we more leaning towards throttle cut induced by overboosting...so I was thinking maybe the N75? I am trying to borrow one to test if that is the problem or not...and I am running the 10secS4 hybrid file.
    Veteran Member Four Rings gointoscott's Avatar
    Jan 26 2006
    2001 Audi S4
    Milwaukee, WI
    throwing any codes?
    Original K03's, Ecodes, H&R Coilovers, Inmotion Chip/MBC, Piggies
    Active Member Four Rings ///M3 TO S4's Avatar
    Feb 09 2007
    Charlotte, NC
    I have a very similar issue, i'm swapping my N75 valve for my buddies, i'll report back to you this weekend. It's quite an annoying issue. My boost will spike up to 24-25, fall to like 15, then near redline go back up to 23-25lbs
    Learn MANTH America!
    Stage 3....blah...blah...blah... : Sold
    Now: E36 M3 TURBO (GT35R)
    Oct 02 2006
    2001 Silver S4
    Watertown SD
    Quote Originally Posted by ///M3 TO S4 View Post
    Alright thanks! Let me know what you find out. It is annoying the heck out of me, because an easy way to describe it, is it feels like you are shifting gears every second...so it feels really slow. I ordered a MBC as well to see if running it in parallel will maybe help?
    Oct 02 2006
    2001 Silver S4
    Watertown SD
    By the way, what setup do you have for turbos and fueling?
    Feb 09 2007
    Charlotte, NC
    Quote Originally Posted by jaredsogn View Post
    awe fuel with the electronic boost controller option set higher than what it comes with....PJ K04's
    Jul 26 2008
    Jersey
    See my post on AW..
    Also, I'm running a 1.8T N75 race valve.
    My car spikes to 23 and just holds 23.
    Oct 02 2006
    2001 Silver S4
    Watertown SD
    Quote Originally Posted by spinny View Post
    See my post on AW..
    Which post are you talking about?
    Jul 26 2008
    Jersey
    I replied to you over at AW, spinny201 is my username there.
    Senior Member Three Rings xtort44's Avatar
    Oct 04 2005
    MD but my heart is in Vegas
    my car is doing this too. Anyone come to a conclusion. Running OTS complete AWE rsk04 kit.
    Casa Stage 3 s4
    Veteran Member Three Rings NogaroWonda00's Avatar
    Jun 13 2008
    Rocky Mountains
    there is a good possibility your on the right track, id also pull the plugs and check the gap, and the coil packs. clean your maf sensor with some throttle-body parts cleaner too.
    is it cutting out right at/after full boost hits or on the way to boost?
    any missfire codes as well?
    '00 Nogaro Blue S4
    Dec 30 2008
    Montreal, Canada
    I think about overboost. Request vs actual = To much difference.
    i put an MBC on mine for cut my pike and now 0 throttle cut.
    PS, How do you made this diagram? Which software.
    Veteran Member Four Rings Tifosi's Avatar
    Apr 27 2004
    Pacific NW
    Quote Originally Posted by xtort44 View Post
    What ICs are you running, AWE ?
    Established Member Two Rings audiSUKKA's Avatar
    Jun 26 2009
    2001 audi s4
    San Diego ca mission
    I think it could be the 02 sensor.
    Feb 09 2007
    Charlotte, NC
    Quote Originally Posted by audiSUKKA View Post
    no....not even close
    Jun 14 2007
    2000 S4
    Connecticut
    Old thread!
    Since then Jared has switched to a VAST Tune running strong!
    Oct 04 2005
    Quote Originally Posted by Tifosi View Post
    ER IC's
    Casa Stage 3 s4
    Oct 04 2005
    FWIW put in a new, well used, n75 and my problems disappeared. Special thanks goes to thirdstrike for helping me out.
    Casa Stage 3 s4
    Jan 26 2006
    2001 Audi S4
    Milwaukee, WI
    new, well used
    lol that sounds a little contradictory. But glad to see its fixed.
    Oct 04 2005
    had it sitting around so figured why not give it a shot. can't beat free!
    Casa Stage 3 s4
