Results 1 to 17 of 17
    Oct 16 2008
    Romania
    Heated mirrors problem
    My mirrors are heated and by chance I touch them and noted that they are hot. The external temperature was above 20C. Finally I removed the fuse no. 9 in order to stop heating.
    Does any one knows how the heating on the mirrors is controlled?? Something must be wrong in the car, but I can not figure out what it is and where it is.
    Veteran Member Four Rings zrowcool's Avatar
    Nov 09 2006
    2000 B5 A4 Quattro / 00 F-150 XLT S/C
    Bronx, NY
    Re: Heated mirrors problem
    i think they are on all the time as long as the ignition is on. not 100% but i think i remember reading it somewhere
    2000 A4 1.8tq
    Running only on Amsoil fluids.
    Amsoil products at wholesale pricing... Ask me how!
    Veteran Member Four Rings hoganalley's Avatar
    Feb 23 2007
    Burlington
    I always thought they were only on when the adjustment knob is in the middle. If you turn the knob to either L or R, then they don't come on. I could be wrong....
    14 A4 allroad - stock
    05 allroad 2.7T Stock
    Active Member Two Rings shawn120's Avatar
    Nov 04 2007
    Vancouver
    for the B6 , the mirror heating is controlled by the rear defrost button. They are heated whenever it is on
    Nov 09 2006
    Bronx, NY
    the middle is only so you dont move the mirrors accidentally with you arm or whatever. kind of like a lock.
    2000 A4 1.8tq
    Feb 23 2007
    Burlington
    yeah, I knew that, but I read that somewhere.......I forget where. Might have been on here......
    Veteran Member Four Rings offroader1006's Avatar
    Oct 17 2004
    77 International Scout II, 73 911 2.8RS, 2010 Cayenne
    Columbia, SC
    thye only come on when the rear defrost is selected
    Oct 16 2008
    Romania
    Nope, the heating of the mirrors is ON, even the heating of the back window is OFF. I had to remove the fuse to turn it OFF, while the heating of the back window is still working, so they are indepented.
    Any one really knows????
    Oct 17 2004
    Columbia, SC
    they have 2 different fuses. 26 for the def switch, and 9 for the heated mirrors.
    haynes manual has them powered at all times, maybe someone with a bentley manual can tell you different.
    Oct 16 2008
    Romania
    In case they are powered all the time, they might be fitted with a thermal switch or any such kind of device that are self activated at certain temperature. I can't belive that they are ALWAYS ON.
    Does some one has any drawing which can share with us????
    Veteran Member Four Rings Silverstreak98's Avatar
    Dec 11 2006
    Minnesota
    This has been a mystery for a while I am interested to know.....although I think one or both of mine are not working.
    ~Brian
    1998.5 A4 2.8QT
    Oct 16 2008
    Romania
    I found this intresting modification to make the heating of the mirrors work with the heating of the rear window.
    http://www.audiworld.com/tech/elec18.shtml
    However, this still does not answer the basic question from where the heating of the mirrors is controlled.
    I have a feeling that it is an indepented thermal sensor or it is part of the external temperature monitoring system i.e. similar to the one that does not allow the air condition to start when the external temperature is below +3C.
    The next days I will make the above modification but if I could connect it to a temperature control sensor it will be even better.
    Oct 16 2008
    Romania
    FInally I did the above modification and now the heating of the mirrors is working with the read window heating switch. The switch is staying ON only 15 minutes, however, I hope this is enough.
    I wanted to find a temperature activated switch that will get ON for temperatures below +5C, but I could not find.
    So far the modification is working ok, the only ashame is that finally we could not find how the heating of the mirrors is working. I dont believe that it is always ON, just could not find how it is activated.....
    Nov 03 2008
    Boston
    From what Ive read in these posts and the posts in the other audi forums, it seems the heaters are always on. It also seems that this isnt harmful since it has a bimetallic strip which is instrumental in the heating. Dont ask me why that makes it better, I dont know.
    Oct 16 2008
    Romania
    The metalic stipe is on the left (bigger mirror), the right mirror is without this stripe. I dont know also waht this stripe is doing but is not related to the heating beacuse both mirrors are heated.
    I asked even in the service of Audi, they did not had an idea about the operation of the heated mirrors, but I think that should not be always ON. Of couse last winter I was asking them why my A/C was not working and they did not had any idea to tell me that below 3C the A/C is designed not to start.
    Most probably the heating of the mirrors is conrolled by some temperature activated device which now in my car is not working. Everything else is working ok, at least I believe so.....
    Active Member Four Rings burner799's Avatar
    Oct 14 2006
    Hermosa Beach/PHX AZ
    did your car have to have the cold weather package to have heated mirrors? I have the bluish hue, but no little box with squigly lines that usually mean it's heated
    Ti.Sline: yeah my dads got shit in order
    SkunkonCrunk: i had to pay $300 and fight the city after they sprayed a bike lane on my car
    SkunkonCrunk: i hear ya, i know u guys dont get along but let bigons be bigons, or however u spell it, im at a two year
    Oct 16 2008
    Romania
    I dont know if it is the cold weather package, I dont have heated seates, or steering wheel, only heated mirrors, heated water spays and heated back window.
    I understood that the mirrors were heated on time during summer when I tough them and were hot.
