Results 1 to 8 of 8
    Apr 01 2005
    one wagon one truck
    Michigan
    Sunroof Cleaning
    Does anyone know of a good DIY to clean the rails and lube them up?
    Account Terminated Four Rings
    Oct 28 2006
    GT30r'd A4 on Meth, 01 Durango
    Re: Sunroof Cleaning
    drop the headliner and you have full access to the sunroof
    Veteran Member Three Rings generik777's Avatar
    May 12 2007
    1998.5 A4 2.8 Quattro Tip
    MN
    What's the best thing to use on it? I have some white lithium grease, good enough?
    Apr 01 2005
    one wagon one truck
    Michigan
    yeah I was looking for more like products to use and what parts I should focus on most.
    Apr 22 2007
    Riverbank, Ca
    I used white lithium grease to good results. I just opened it up, sprayed the shit in and sprayed it while it closed.
    Veteran Member Four Rings Kronic Budz's Avatar
    Oct 01 2007
    1997 A4 2.8 QM
    San Diego, California
    i got some crc white lithium grease and im just going to do like the guy said above. spray the rails and everything while it opens and closes. Ill let you guys know how it goes.
    1997 Audi A4 2.8 QM black on black
    bilstein sports w/ vogtland sports ~ S4/sport sway bars ~ 17x8 Bremmer Kraft Br05 wheels et33~ BF G's Sport COMP 2's 225/45/17 ~ Custom Exhaust ~ CAI ~ Ebay SS ~ SS brake lines + EBC red stuff ~ 35% tint/70% front tint ~ face lift headlights w/ 5000k HID + tails ~ blacked out grill trim~ kenwood mp3 ~ Polk comp 5.25" Front mm speakers ~ Infinity REF 6.5" rear speaks ~ 10" Rockford Fosgate p2 in sealed box ~ ED nine.4 4ch. amp powering woofer/polks[/I]
    Apr 14 2010
    Madison/WI
    would WD 40 works?
    Jun 30 2008
    Erie, Pennsylvania
    No, you want a type of lubricant that is going to stick around. Something with a little thickness to it. The white lithium grease should work well.
