Results 1 to 12 of 12
    Dec 05 2007
    Does anyone know the size of the control arm pinch bolt?
    That motherf*cker just snapped on me
    Edit: Ok, f*ck this thread (sorry for my vulgar attitude, but I am rather perturbed at the moment). I have to bring my car to the mechanic now to have that sh*t drilled out. Ahh, another week without my vehicle. Schedued for next Thursday and I already had my car down since last week. Aint life just grand .
    Veteran Member Four Rings A4 Effort's Avatar
    May 28 2007
    '99 A4 2.8 / '07 A4 S-Line Avant / '09 A4 S-Line 2.0
    Mt. Airy, MD
    Re: Does anyone know the size of the control arm pinch bolt?
    Have you tried using a heat-gun or torch on it and then banging it out with a piece of drift?
    | 2007 Ibis Ti S-Line Avant | APR Stage 2+ | APR HPFP | 034 HFC | Forge DV | Stasis Exhaust | KW V1 Coilovers | SPC Adjustable Control Arms | 19" MRR GF6s | 034 TIP | 034 Sway Bar & End-Links | K&N Drop-In | Deval CF Front Splitter | Relak CF Sideskirts | S4 Recaros | TT-Sline MFSW | P3 Vent Gauge | RS4 Grille | RS4 Fog Grille Mod | RS4 Pedals | RS6 Shift Knob | OEM+
    Dec 05 2007
    I feel like saving myself the headache and having the professionals do it. I have too much stress to deal with besides adding more from the contents of my vehicle. Should not cost more than $200 for everything I need done. Hopefully cheaper.
    Dec 03 2005
    2 pedals 1FG
    connecticut
    What size is it? For the upper control arm - spindle interface? I need to know. The ones on my friend's B5 are not reusable.
    -Doug
    Dec 05 2007
    What up Dougy? If you don't get an answer by next week, I will PM you the size. I will ask my mechanic.
    Registered Member Two Rings manufan's Avatar
    Nov 16 2007
    98 A4 2.8 QM 93 Ducati 900ss
    northern pa
    I'm going to change a control arm right now. I'll measure it and post the size up.
    Nov 16 2007
    northern pa
    The bolt is 10mm x 1.5 x 100mm long, standard grade
    Nov 04 2008
    fort dodge,ia
    Hey, just wondering if there is anything special to this bolt.[is it just a common bolt]. Mine is stuck in there as well, and by the time I get it out its definately not gonna be reusable.
    Dec 05 2007
    Quote Originally Posted by jonessw20 View Post
    Quote Originally Posted by manufan View Post
    Must be standard grade if it just snapped on me. But rust was the deciding factor.
    Sep 23 2008
    San Francisco
    I am so glade mine is a Cal car, did the control arm last week and the bolts came right out, without even using any WD40.
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    Wonder if a shoulder bolt could be used. That could prevent the problems associated with the normal bolts as well as provide a much better surface to capture the upper joints.
    Jim
    I Do Werk.
    Veteran Member Three Rings generik777's Avatar
    May 12 2007
    1998.5 A4 2.8 Quattro Tip
    MN
    If it makes you feel any better, I've been without my car for about 2 months now just waiting for a simple intake gasket. The mechanic ordered it from someplace that called hime 3 weeks later and said they couldn't get that part anymore. He then ordered from somewhere else that also called him later and said the same thing. He finally just ordered it from the dealer and got it in the other day. Now he's gotta wait till he finishes one of the cars hes got in there so he can fit mine in. Very frustrating
