Thread: Eurojet PCV fix
    Oct 03 2008
    93 White NX2000, 2005.5 B7
    Lancaster, PA
    Eurojet PCV fix
    I've been trying to find things on here about it, but no luck. I see that a few people have it in their sigs though. I was wondering if this is as straight forward is it seems and if the stock engine cover will still fit. I've been trying to read about in the vortex forum, but it's a million pages long about nothing that helps me. A quick answer would be greatly appreciated. I have a 2005.5 2.0T.
    Thanks
    Joshua
    Veteran Member Three Rings extremesport3's Avatar
    Apr 14 2008
    '11 Jeep Wrangler Unlimited, '90 BMW 325i
    Oceanside, New York
    Re: Eurojet PCV fix
    Josh, i have it and it fits perfectly. The only thing you will have to do is cut one of the silicone lines because otherwise it will hit the fuel pump. Make sure you put the check valve in the correct way.
    John
    BMW M3 ZCP
    2005 - TiAg/Cinn - 6spd
    CSL Headers, Euro Cats, Recaro Pole Position, Schroth Quickfit 4 Pt, Autosolutions SSK 42%, BMW M Sport 4:10 rear diff, Rogue Rear Lower Control Arms, AST D/A4200's w/ 550f/650r, Vorslag Camber Plates ,H&R Front Sway (30mm), Stop Tech ST40 (fronts) , PFC06 Pads(f) PFC01 (r) , TR Motorsport 18x9.5 w/ Direzzas (265/35) (track setup), Vorsteiner Carbon Fiber Trunk, ACS RW diffuser, ZHP shift, VCSL Diffuser
    Oct 03 2008
    Lancaster, PA
    Re: Eurojet PCV fix
    How is this compared to the new version PCV valve? I'm just not quite sure which one to spend the money on.
    Veteran Member Four Rings quattrosaint's Avatar
    Sep 24 2007
    Dallas
    Re: Eurojet PCV fix
    Quote Originally Posted by extremesport3 View Post
    John
    X2, boost seams more consistant
    2007 A4 Quattro 2.0T Tip
    Go Fast:Custom GIAC Tune & APR HPFP & AWE FMIC & AWE Exhaust & Labree DP & K&N Filter & Forge DV & Eurojet PCV
    Stop: ECS Stg 4 Porsche BBK
    Twisties: H&R Springs & RS4 Sway & Ti Rims
    Stunt: S4 Grill & S4 Rear & Cupra R Spoiler & TTS Wheel & 8MM Spacers & CF Trunk
    Now................Mostly parted out. Thanks everyone who participated
    Veteran Member Three Rings matttl16's Avatar
    Feb 25 2007
    2007 audi a4 and 2010 audi a3
    phoenix az
    Re: Eurojet PCV fix
    i have it as well and i still have problems... ive had this "fix" for a while... accually it was fit to our cars using my car and now its not doing its job... there is a new pcv replacement comming out from another shop really soon!!! i will take pics as soon as i get t fit up.
    07 b7 a4 2.0t stage 3
