Results 1 to 26 of 26
    Established Member Two Rings STaSIS_2.0T's Avatar
    May 20 2008
    2008 STaSIS/Audi A4
    Chicago
    How do I remove the rear seats?
    Need to lay something flat to move on saturday and also heading to the track this sunday (wouldn't hurt to loose a bit of weight). Thanks
    STaSIS/GIAC ECU | ITG ProFilter | EvolutionRacewerks SMIC's | STaSIS exhaust | STaSIS/Koni/Vogtland suspension | STaSIS/Alcon 355mm Mono4 brakes | Volk CE-28 19x8.5 | Toyo T1-R 265/30 | O.Z. Superturismo GT 18x8 | Dunlop Wintersport 3D 235/40 | JHM short shift kit | ECS snub | RS4 rear sway | RS4 pedals | S4 shift knob | RS4 grill w/s-line chrome surround | VMR vent boost gauge | 034 Intake Pipe | CoolBoxMod | Hardwired 8500 X50 w/"OEM" mute button |
    Veteran Member Four Rings cstarky15's Avatar
    Feb 16 2008
    Oakdale, MN
    Re: How do I remove the rear seats?
    ask Doctor!
    The usual things!!
    Resistor Install
    May 20 2008
    2008 STaSIS/Audi A4
    Chicago
    I would but he has a different setup. He doesn't have fold down seats
    Veteran Member Four Rings Six Speed Turbo's Avatar
    Feb 09 2007
    Hopes, Dreams, Tools, Car Parts
    Killeen, TX
    Well I hope you find your answer, because I would like to know as well.
    2016 S3 Prestige - Glacier White Metallic, APR Stage 3+, APR TCU upgrade, APR CAI, APR FMIC, APR Catchcan, APR Lowering Springs, P3 Guage
    YouTube Channel https://www.youtube.com/channel/UC88...LbgXXvRHPvW3Xw <---SUBSCRIBE
    Senior Member Two Rings dobos100's Avatar
    Dec 13 2007
    los angeles
    Quote Originally Posted by STaSIS_2.0T View Post
    Well I learned the hard way, by actually removing all of the brackets, but the right way to do it is like this.
    1,The bottom section of the seat comes out by firmly pulling up on them, the 2 points where it clips into the floor are roughly 12" from the side on the front. This part weighs next to nothing.
    2, fold your seats down, at the separation, where the seats pivot,there is a 3x3/4 inch plastic cover that pops off. Revealing a single screw.
    3, Take out the screw and remove this metal retainer that the screw was holding.
    4, full up on either section of the seat (you will have to fold it up from the flat position a little bit) to loosen it form this bracket, once loose pull the seatback away from the corner it is still attached to. The seat should slide free.
    5, disconnect the seatbelt
    Done.
    Feb 09 2007
    Killeen, TX
    Very nice.
    May 20 2008
    2008 STaSIS/Audi A4
    Chicago
    Quote Originally Posted by dobos100 View Post
    Done.
    thanks dude, appreciate it
    Nov 12 2007
    Grand Junction, CO
    You really can't just flip down the top section?
    May 20 2008
    2008 STaSIS/Audi A4
    Chicago
    Quote Originally Posted by AudiWxGuy View Post
    NOPE
    Dec 13 2007
    los angeles
    Did i miss something? what do you mean your seats do not fold down? I thought they all did. If they do not fold down I don't think my instructions work. Except for the bottom seat.
    Nov 12 2007
    Grand Junction, CO
    That's what I mean. The tops fold down and they lay almost flat.
    May 20 2008
    2008 STaSIS/Audi A4
    Chicago
    they do but need a completely flat surface. moving my cousin's art project
    Nov 12 2007
    Grand Junction, CO
    i would imagine that once you take the seats up, it may not be flat under there either. Usually the bench slopes down a bit.
    May 20 2008
    2008 STaSIS/Audi A4
    Chicago
    My original plan was to just fold the seats down and lay something in the truck to make it flat. However I wasn't ablt to get enough height clearance as it would destroy the model so i'm gonna have to compensate but need extra height clearance. Should work for sure
    Nov 12 2007
    Grand Junction, CO
    Nice.
    Veteran Member Four Rings Doctor's Avatar
    Jun 02 2008
    A4 B7 20vt Quattro,Golf MKV GT
    Greece
    Well I just saw this thread, and I would like to help...If u need anything, tell me ok...?
    However yours with folding seats is a lot easier...
    Apr 18 2008
    Jacksonville, FL
    i'm just trying to remove the seat bottom. is the Avant the same? just pull up? i did that, and i heard a snap on both sides, but the seat only lifted an inch or so, and i can't get it to secure back down.
    2011 Toyota Tacoma Double Cab SR5
    SOLD 10/2011
    2008 A4 Avant 2.0TQ Tip in Quartz Grey
    APR Stg 1; RS4 Rear Sway; 034 Turbo Inlet Pipe; 35% tint; 640 SWITCH mod; GROM-I2-VAGD + Proclip
    Apostrophes: how to use them Baby Jesus cries when you misuse apostrophes.
    Jun 02 2008
    Greece
    U have to put the clips back on...Not easy though...
    If I find it on an ELSA sketch I had, I will give it to u
    Senior Member Three Rings Allan T's Avatar
    Sep 28 2006
    Audi a4 b7 2.0 Tfsi quattro avant sline
    Sweden
    Here are some pics of the seat bottom:
    Allan T
    Mod list = To long to write.
    http://www.garaget.org/?car=118660
    Veteran Member Four Rings supamannn99's Avatar
    Nov 15 2007
    Orange County, SoCal
    Nice. Was about to ask about pictures
    Sep 28 2006
    Sweden
    And here is some pics of the top of the rear seats:
    Allan T
    Jun 02 2008
    Greece
    so much easier when having folding seats...
    too bad i had forgotten to add that...
    Nov 15 2007
    looks like a bitch to do. complicated german shit ftl
    Jun 02 2008
    Greece
    And think...This is a piece of cake compared to mine which are not folding...
    Where u must have a tool that only dealerships do have...
    So dont even mention it...I had e avery hard time taking these off...
    Sep 28 2006
    Sweden
    Quote Originally Posted by Doctor View Post
    If you want the tools that the dealer has, look after "Hazet tools", it use to be what the use of tools.
    Jun 02 2008
    Greece
    Quote Originally Posted by Allan T View Post
    I went to a friend of mine that works in a dealership , and he made me a favor and did it for me...So for the moment i am ok...
    I've ripped a lot of cars, but hell, A4 B7 has been reaaaaly difficult guys...
    Yesterday I removed the rear harnesses, along with sub and other components and it really took a lot of time and effort to achieve it...
