Results 1 to 4 of 4
    May 19 2008
    Quebec, Canada
    I cannot take it anymore! Boost/radiator?
    OK my 2003 1.8T slightly modded (chip, injectors, fmic, cat-back) is giving me headache as I can't fix the problem that causes :
    -The radiator fan to start as soon as I start the car, even if the car's cold!
    -My boost to drop from 18 psi to 5 psi in a second (happens when the fan finally turns off, after 1/2 mile)
    -A sweet check engine light that I scanned : Unknown Code - Intermittent. Missfires.
    WTF??
    The boost can come back for a couple of days and everything is normal, even the CEL was once gone when I had boost, but I always lose it again! And it happens in a second, you really feel like the drop of power as if I the asphalt would suddenly turn into glue!
    I need your help, as my local shop don't even know where to start!
    Thanks a lot
    Simon
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    Re: I cannot take it anymore! Boost/radiator?
    Sounds like you have a bad fan control module, it's located on the rad. fan shroud in frt. of the intake manifold. It might be throwing the ECU into limp mode. This just a guess.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    May 19 2008
    Quebec, Canada
    Well you were right about the limp mode, but I figured out that the temperature sensor was guilty, once changed everything went back to normal!!
    And now my headaches are gone! YAY
    Mar 21 2006
    Lakeland, FL.
    No problem. Was it the one on the back of the head on for the fan in the lower hose, for future reference.
    I'm back bitches!
