Results 1 to 33 of 33
    Veteran Member Three Rings dak360rt's Avatar
    Apr 17 2008
    Sacramento, Ca
    F&#%ing Cup Holder
    i searched the forums, and found out how to remove the cup holder, but now i need to fix it...
    Basically the part inside that allow the cup holder to automatically open when you press it has come out completely and if i could get inside the cup holder im pretty sure i could fix it....
    So does anyone know how to open up the cup holder it seems to be sealed all the way around
    thanks
    Marty
    Light Silver Metallic - 2001.5 S4 - APR Stage 2+
    Piggy Pipes --- CC Mod --- Darintake --- Samco TBB
    AWE Boost Gauge --- 1 touch rear windows up
    JHM Weighted Shift Knob --- JHM Solid Short Throw Shifter --- Custom Straight Pipes
    Apr 17 2008
    Sacramento, Ca
    Re: F&#%ing Cup Holder
    okay audi world has an article on how to get into the cup holder now.....how does anyone know where the silver coil thing goes?
    Apr 17 2008
    Sacramento, Ca
    Im a one man thread
    I figured it out....its just broken.....i might try some tape or something but the plastic that holds the metal spring coil (plastic holding metal <---great idea audi) broke and the metal coil now just slips out of its place
    Marty
    Senior Member Two Rings nvrfollow's Avatar
    Apr 19 2007
    Silver S4 - Laser S4
    Montana
    I just said fuck it, threw away the coil and padded the back of it up with a little duct tape spacer square.
    Apr 17 2008
    Sacramento, Ca
    That will be my last resort becuase i really dont want to drop $70 on a new one...i wonder if my warranty covers that, ill look into it.
    Basically i put the clear plastic piece that lights up the icon on the front in place and then i used silicone to glue the silver coil to the top of the clear plastic piece, and then i put a few layers of tape on top of it, the silicone says it takes 5 days to cure, so im gonna wait and see how that works
    Marty
    Veteran Member Three Rings Chknkatsu's Avatar
    Feb 08 2008
    2010 Wrangler Unlimited 6spd, bmx bike, 337 GTi (SOLD)
    Whitestone, NY
    poor guy, 4 responses and 3 of them are by yourself
    __________________________________________________ ______________________________________
    $4c@b
    "I like to hide behind my sunglasses and check out the underage girls."
    WGLYC
    S4SugarHips
    "my name isn't mike."
    Mar 21 2008
    i cant get my cup holder out
    or the bottom peice underneath the Ac/ Heat buttons
    Jun 14 2007
    2000 S4
    Connecticut
    i know your pain man. I bought this car stock and it came with a leaking rearview mirror and a cupholder that wouldnt go in all the way. a buddy of mine helped me take it out, we removed the spring that got all fubared in there and now it goes in all the way just doesnt come out....
    do NOT spend 70+ from audi, contact SHOKAN parts. they are 45 dollars.
    Veteran Member Three Rings TheDarkness's Avatar
    Jul 13 2008
    15' A3 2.0T , b5 S4 Stage III
    put a Greddy turbo timer in that bitch
    2001 Stage III Pearl White B5 S4: Frankenturbo F21s | Iforged Flux | Solo Motorsports Dyno Tune | Bosch EV14 52#
    2015 A3 2.0T 8V Mythos Black: KW V3s
    Established Member Two Rings jesterekim's Avatar
    Aug 26 2007
    2001.5 Audi S4
    New York
    The cup holder is the best feature of a S4's interior.
    Stage 2 | Brilliant Black | 6-speed
    GIAC X
    APR Stealth Catback
    APR Bi-Pipe
    Pro DFI Boost Gauge
    Veteran Member Four Rings AMC's Avatar
    Jun 15 2007
    '19 Spektrum Golf RS, '18 Audi TTRS
    thats right, rich bitch lol...but yeah i like the idea of the TT in the cup holder spot but i cant remember which one fits in there perfectly
    Driver Supply
    Current
    '19 Spektrum Golf RS DAZA
    '18 Audi TTRS
    Sold
    '07 Stage 3 2.7t swapped B7 A4
    '01.5 Stage 63463 Silver S4
    '13 black Audi S7
    '03 Porsche 911T
    Mar 11 2007
    1990 R32 GT-R
    Somewhere in CT
    Oh yea, thanks for pressing mine in. Its still stuck.
    Veteran Member Three Rings DefiantS4's Avatar
    Jul 30 2004
    Houston, TX
    Yep, I had the exact same problem with mine. Sharp metal edges + thin plastic retainer = fail. I tried everything to fix it... epoxy, plastic weld, even a piece of carbon fiber. All failed. You're better off just getting a new one.
    Past - '01.5 S4, APR Stage III
    Apr 17 2008
    Sacramento, Ca
    thats defiantly not what i wanted to hear. Can you edit that to read, "some random adhesive that is designed for wood or fiberglass and a strip of off brand name duct tape patched it up perfectly...i recommend it to anyone, save money"
    It would be greatly appreciated
    Marty
    Jun 14 2007
    2000 S4
    Connecticut
    lol. well hey 45 dollars is better than 100.... so contact shokan
    www.shokan.com
    and order one :)
    Jun 14 2007
    2000 S4
    Connecticut
    Quote Originally Posted by AMC83189 View Post
    I give credit when credit is earned lol! you fixed that for me im still grateful
    The Greddy TT Fits in there.... I may do that but I hear the wiring isnt that easy on it..
    Jun 14 2007
    2000 S4
    Connecticut
    Quote Originally Posted by grAh4m View Post
    lol im very sorry for that. haha
    Apr 17 2008
    Sacramento, Ca
    Ill do that if my homebrew attempt doest work out, but like the golden state wariors playoff run, "we believe"
    Jul 30 2004
    Houston, TX
    If I told you what you wanted to hear you'd be back here in a few days saying that you were led to believe it would work. If you plan on leaving the cupholder extended permanently it might work. Otherwise, the thin metal edges of that coil are constantly going to be pulling against whatever you rig up against it. The OEM injection-molded couldn't handle it, so one can say that anything adhesive based just isn't going to work. And if it does, will it still function like OEM? Not trying to be a downer, I was in the same boat once and messed around with it for months. The cheapest and easiest solution is going to be finding someone in the classified parting out a B5. I've seen used cupholders go for $20-$30.
    Apr 17 2008
    Sacramento, Ca
    Veteran Member Three Rings DoGGRoBBer's Avatar
    Dec 24 2006
    2000 S4, 2008 Touareg
    Upstate NY
    Do you really want a liquid that close to your stereo? Bad Audi OEM placement... $45-70 to fix?? WTF?? It's a cup holder....there are two under the arm rest...ways away for electronics... Is it just me or does this seem to be a strange thing to worry about?
    2000 S4 SSP Tuned Stage III ,K04's,SSAC Downpies, Scorpion Exhaust, RS4 Clutch, APR Bi-Pipes, APR Snub mount, VAST MBC & TCD running 20-22 Psi., APR SMIC, Bosch 710N DV's
    2008 VW Touareg
    Apr 17 2008
    Sacramento, Ca
    i use it all the time, i dont drink soda so the only thing it sees is a water bottle with a cap on it. In fact tonight i forgot that it was out of the car and when i got in i tried to place my water bottle there and felt really defeated when i realized it was gone. As far as the other cup holders go i have to have the arm rest down all the way so i can get my gansta lean just right and no drink except maybe a 5 hr energy drink can fit under it.
    Marty
    Jun 14 2007
    2000 S4
    Connecticut
    Quote Originally Posted by DoGGRoBBer View Post
    when i was new to AZ i actually made a thread titled ....the amazing cupholder above the radio... LOL
    http://www.audizine.com/forum/showthread.php?t=153267
    but, yeah. i wanted to replace it with the coin tray that comes in like all roads and in the european cars. they dont have the cupholder there we fatty americans make it a us spec to have it
    Registered Member Two Rings Knight_Rider's Avatar
    Feb 26 2008
    Go f*ck yourself!
    you are prolly going to have to rip it out. use a pick-tool and get in there, than pull. after you pull it out, and it breaks, replace with new one, or fill w other electronic display, device, garb, etc.
    I am Michael Knight, my car is K.I.T.T.- The Knights Industries Ten Thousand, my organization is F.L.A.G. I am powered by Garrett/Honeywell and GenerationJDM.
    Veteran Member Four Rings nizmosx's Avatar
    Feb 13 2004
    2007 b7 a4 6MT Ti avant / 1990 300zx TT / 2014 Honda Grom / 2012 Tiguan SE
    Lakewood, CA
    i believe the turbo timer that fits in there perfect is the all black greddy tt 3.
    Veteran Member Three Rings DanS4's Avatar
    Oct 03 2008
    01.5 Audi S4, 00 golf Tdi
    Reading, PA
    I have search the forums and i cant figure out how to fix it. Can you please post me a link. Check my picture in the sig, stupid cup holder.
    SOLD Silver 01.5 S4 ; VAST tuned k04s, piggies, ASP exhaust, FMIC, Tracksports, DTS, ...
    http://www.socals4.com/
    Jul 13 2008
    you have to take out the trim surround first
    Jun 15 2007
    your welcome and thank you
    Driver Supply
    Current
    '18 Audi TTRS
    Sold
    '13 black Audi S7
    '03 Porsche 911T
    Apr 17 2008
    Sacramento, Ca
    I'm on my blackberry now, but when I get back to my laptop ill find that diy for fixing it, I think it was on audiworld.com
    And my fix failed, when I put it all together again, it worked for 2 days and then broke again, although I didn't have the best materials to do a great job (duct tape and random adhesive)
    I might try again for the fun of it or just give in and call shokan
    Veteran Member Three Rings Rajan147's Avatar
    Nov 23 2007
    Columbus, OH
    B5 S4 AWE Stage 3 - sold
    Registered Member Three Rings volks88's Avatar
    May 06 2007
    stg3 s4,02 C32 AMG,88 325IS
    lexington,ky/fond du lac,wi
    i have one i just removed tonight. perfect working order. $45 shipped
    Oct 03 2008
    Reading, PA
    Apr 17 2008
    Sacramento, Ca
    Thats how to get the cup holder out of the dash
    http://www.audiworld.com/tech/int59.shtml <--- this is how to disassemble the cup holder once its out of the dash
