Results 1 to 12 of 12
    Veteran Member Four Rings Boosted3.0's Avatar
    Jul 27 2008
    02 A4 3.0, 08 M5 5.0
    Miami, FL
    Best 3.0 Coilpacks
    Well on start-up I keep misfiring and it's throwing the cel about every two tanks of gas. So I figure I should replace/upgrade my coil packs. Where did you find your coil packs for the 3.0, and what are the best ones?
    High speed Ferrari movement...
    Veteran Member Four Rings nimski62's Avatar
    Mar 11 2008
    2005.5 B7 S4 6mt, 2002 b6 3.0Q
    Pierceton, Indiana
    Re: Best 3.0 Coilpacks
    Quote Originally Posted by Boosted3.0 View Post
    Try ECStuning.com.. and i would strongly reccomend that you get that checked out by PES, may be something besides coilpacks, I had a 3.0 motor blow up bc of their shit s/c.
    Sep 23 2006
    Houston TX
    carson at riversideaudi is a good source. sign up for an account through AW.
    I'd scan the codes first though. might be due to something else.
    Jul 27 2008
    Miami, FL
    Quote Originally Posted by Ill 3.0 View Post
    Yeah I did its multi misfire and cylinders 4 and 5 I believe. I am getting alot of carbon buildup on my exhaust so I know I'm running rich, but I'm afraid to have PES lean it out because I'm stock internals.
    Sep 23 2006
    Houston TX
    you using a 4 bar fpr by chance? I agree that you don't want to be leaning out. What do your plugs look like? Mine got pretty black in less than a year just after winter.
    Veteran Member Three Rings dpatel's Avatar
    Oct 03 2005
    Atlanta, GA
    Are you getting the misfires when the engine temps are not up? If the engine has not warmed up completely, you can get a cell if you push it too hard. I would not go over 4K with it not warmed up completely.
    I also just cleaned out my cone filter. It was caked with dirt and sud. You could not see it if you look at it, but bang it against the ground and walllaaa. Car runs much smoother now and my MPG computer rating is up by 2 from before.
    - 3.0 Quattro
    - Milltek Exhaust with 4" Tips
    - Hyperflow Intake
    - Caracter Front bumper
    - Eibach Pro Kit + Bilstein Sport Shocks and S4 Rear Sway
    - Sportec 18" wheels
    - Stoptech Slotted Rotors with Ceramic Pads
    - Level 10 VB & APR Snub Mount
    - G3 SuPeRcHaRgEr
    VP of 3.0 CLuB
    Veteran Member Four Rings T0M3K's Avatar
    Sep 14 2007
    Valley Stream, NY
    Hey nimski62 what's up with your supercharger?
    Veteran Member Four Rings skeeball's Avatar
    Sep 20 2006
    Baltimore
    For CP's, I get the latest rev from Carson. But the misfires could just as easily be plugs.
    Jul 27 2008
    Miami, FL
    Idn I'm going to pull the plugs this weekend when I'm back home, there about a month old but I'm sure there going to be dirty.
    I'm getting the misfire codes when I start before I even move it. It runs like s#it for the first like 10 seconds just hunting for the idle, I believe this is where the misfires are happening especially since I know it runs lean at startup as all A4s do. I usually let it warm up untill the temp guage comes off cold...lately I've been very busy so I sometimes just start driving keeping it under 3k untill its about a quarter off cold.
    Haven't looked at the filter in a long time, I'll check that tomorrow when I have Autozone clear my codes since I don't feel like waiting for them to go off in a day or two.
    Sep 23 2006
    Houston TX
    misfires only at startup? Could be CP but sounds more like vac leak or maybe clogged injectors. swap CPs from 4 and 5 to different positions to see if the misfire codes change to those cylinders. If that's the case, then might as well order a couple of spare CPs while you're at it to keep in the trunk.
    Senior Member Three Rings ThreePointOhh's Avatar
    Dec 24 2007
    |2004 A4 3.0Q 6SPD MT|
    New York, NY
    the bremi coilpacks from ecs.
    ** I'm Gonna Drive it Till the Rings Fall OFF!! **
    Veteran Member Four Rings thebikedoctor33's Avatar
    Jul 06 2007
    Bremerton, WA
    its good to see people actually tuning 3.0's. all you ever hear about is bt kits anymore, haha.
    good luck with the issue OP, sorry i'm of no help other than words of encouragement. haha
