Results 1 to 11 of 11
Thread: 18010 DTC Code
    Veteran Member Three Rings b5s4tt's Avatar
    Mar 14 2007
    s4
    queens
    18010 DTC Code
    i was driving home before and the battery light came on and i have 12 volts indicated on the dash. i scanned the car and got
    18010 P1602 Power Supply (B+) Terminal 30 Low Voltage VW
    power supply terminal 30: voltage too low
    p1602 - 35-10 --- intermittent
    I cleaned whatever corrosion was on the battery terminal and cleared the codes. Still have battery light and 12volts only. All my grounds look secure, does any one have a suggestion. Im really hoping its not the alternator as i just bought some coils :{
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    Re: 18010 DTC Code
    try getting your battery load tested at vatozone. could just be a cell dying in your battery
    Mar 14 2007
    s4
    queens
    Re: 18010 DTC Code
    thats sucks i should have mentioned this is a 2 month old battery.
    Mar 14 2007
    s4
    queens
    Re: 18010 DTC Code
    bump anyone i dont feel like buying an alternator for nothing. im testing the battery and alt rite now
    Veteran Member Four Rings JDM EJ1 95's Avatar
    Feb 28 2007
    01 Nogaro S4 Stage 3
    chicagoland
    Re: 18010 DTC Code
    Sounds like an alternator.
    battery wouldnt matter when driving.. unless its completely toast.
    if your alternator is out and not pushing any voltage.. it will only show 12 volts(battery voltage) until that battery starts to drain. which will be soon.
    although i was able to drive about 30 miles on battery alone (daytime no radio.. no accessories on at all)
    go grab an oreiles alternator.. thats what i have.. been on for a year with no issues.. lifetime warranty
    Nogaro 01 s4
    24v 2.9L VR6. 6466. Pump gas 10.7 @ 132
    620whp 93octane
    806/767 whp/wtq on C16
    10.4 @ 136 C16 (bad slipping clutch)
    138mph best trap with slipping clutch.
    Mar 14 2007
    s4
    queens
    Re: 18010 DTC Code
    thank you sir. i only have 12 volts with the battery light on. i drove before and had 14volts on initial startup and for 5minutes. my friend says the brushes went bad in the alternator and it is time for a repair or replacement. im gunna check out that oreiles alternator
    Veteran Member Four Rings gointoscott's Avatar
    Jan 26 2006
    2001 Audi S4
    Milwaukee, WI
    Re: 18010 DTC Code
    Start it up. have it idle. take battery cable off while idling. if car stalls when you take battery cable off. it means there's something wrong with your altrnator.
    just by going off what you stated, I'm betting its the alternator
    Original K03's, Ecodes, H&R Coilovers, Inmotion Chip/MBC, Piggies
    May 06 2004
    W124s
    PA
    Re: 18010 DTC Code
    Do NOT remove the battery cable while car is running!! Might have worked fine for your dads 84 citation, but not for any modern car.
    Keep right pass left, it's the law!!
    Jan 26 2006
    2001 Audi S4
    Milwaukee, WI
    Re: 18010 DTC Code
    Quote Originally Posted by quickglx View Post
    Yep pops did show this to me but we never had a chevy citation, they were butt ugly cars
    Anyway, I've never tried it on my car, havnt had the need, but what damage could it cause. just wondering.
    Feb 28 2007
    chicagoland
    Re: 18010 DTC Code
    yea DO NOT do that
    Nogaro 01 s4
    620whp 93octane
    Jan 26 2006
    2001 Audi S4
    Milwaukee, WI
    Re: 18010 DTC Code
    Still waiting for reason why not to try that way of testing alternator? Just for curious sake?
