    Stage 2 Banner Advertiser Four Rings jaybquick@JHM's Avatar
    Aug 24 2005
    Lathrop, CA
    Informational video regarding 6-speed shifter adjustments from JHM
    I made this video specifically for B6/B7 S4 and RS4 owners however the beginning is good info for all 6-speed cars. The rest probably won't help you guys since the B6 B7 A4 6-speeds are way easier to adjust.
    But hopefully the first couple minutes have some good info for you to help you better understand how 1st, 2nd and reverse are adjusted.
    Here --> http://audishifter.com/videos/B6B7_S...e_10-16-08.wmv
    Alternate Link (if download is slow) --> http://jhmtuning.com/videos/B6B7_S4R...e_10-16-08.wmv
    Enjoy, and I hope this info helps somebody.
    JHMotorsports AZ tuner spotlight VIDEO
    Check out our 11 and 10 second passes on YouTube
    B8 S5 4.2l - JHM Stage 1 SC Kit (ET: 11.8 @ 119mph) -- B6 S4 - JHM Stage 2 SC Kit (ET: 11.1 @ 128mph) – JHM Nitrous (ET: 12.29 @ 117mph) - JHM Bolt Ons -ALL MOTOR (ET: 12.70 @ 111mph) -- B5 S4 - JHM RS6-R (ET: 10.8 @ 130mph)
    Veteran Member Four Rings skeeball's Avatar
    Sep 20 2006
    Baltimore
    Re: Informational video regarding 6-speed shifter adjustments from JHM
    Jason, you are the f'ing man. That is the exact issue I've been having. I hand gotten the adjustment so close to where I wanted it but it just wasn't perfect. Thanks for the vid.
    Registered User Four Rings winston@podi.ca's Avatar
    Jun 11 2005
    Pods, gauges and more pods
    Vancouver, BC
    There was a reason it took me hours to tweak the JHM shifter to where it is now.
    Once it is done it engages so smooth.
    Veteran Member Four Rings junkie1.8TQ's Avatar
    Dec 03 2005
    2004 A4 1.8TQ
    Charlotte, NC
    awesome video... going home and doing this tonight.
    2004 Audi A4 1.8T Quattro 6-speed
    • Bilstein PSS9 • APR Stage 1+ w/ TT225 Injectors • Forge 007
    • JHM SS • Oettinger RZ 19x8.5 • Podi • RS4 Rear Sway
    Aug 24 2005
    Lathrop, CA
    I will be interested to see if any of these help you A4 owners since your bottom linkage piece of the shifter is straight unlike the angled bottom piece on the B6/B7 S4. So sliding it around I doubt will help your get it to adjust. However it may a little bit. It works great on theirs since the angled welded piece moving forward and mackward is like a ramp effect.
    thanks guys and glad to keep the info flowing.
