funny that you posted this just now Jason. a few minutes before you did i started a thread documenting my failed install attempt today. I blame it mostly on the tools I had available, but i suppose i'll copy paste it in here for your reading pleasure.
"Earlier today, much to my excitement, my JHM extra short shifter arrived in the mail. So of course, as soon as I found the time, I tried to install it. At roughly 4 o clock, after making a last minute stop at the hardware store to pick up a set of snap ring pliers, I started taking apart the stock shifter, and almost immediately, ran into a problem. I didn't have a 6mm Allen key of any kind. So after a brief debate, I drove my car without the shift knob or sound deadening back to the hardware store to see what I could find.
In the installation video, for those of you familiar with it, they appear to use a socket wrench and extension with a flexible Allen key on the end of it. And of course, with my luck, the best 6mm key the hardware store could supply me with was of course, just a key. Since it was just 89 cents and I was eager to at the very least attempt to get the shifter installed, I went along with it and shortly thereafter, resumed trying to get the stock shifter out.
And I managed to. After a lot of struggling underneath the ashtray with the Allen key, finally the shifter linkages came off and the shifter was out.
Not surprisingly, the first snap ring holding the reverse spring on came off without issue. But all good things must come to an end, and that end came with the second, much larger snap ring holding the entire plastic ball bearing, and thus the entire shifter, in place. The P.O.S. snap ring pliers I purchased couldn't get the large snap ring even close to out. (The pliers were some 15 dollar set that had interchangeable heads, and I really really don't recommend them unless the snap ring in question is really really small.) Needless to say, they slipped every time.
After struggling with that snap ring for a half of an hour, with daylight quickly fading, I realized that I had to give up and get the stock shifter back in and come back to fight another day.
Getting it back in, even just the stock unit, was no walk in the park. Everyone talks about how adjusting the JHM unit to sit right is a PITA. From the difficulty I had, I can't imagine the stock one is much easier. And the Allen key I had in tandem with the ashtray being consistently in the way didn't make it any easier. After maybe another half hour of adjusting the stock shifter, I finally got it seated in such a way that all my gears were accounted for.
However, I'm skeptical that any of the important bolts in the shifter linkage are in their as tight as they should be, thanks to the key. So now, the car is once again drive able, but I'm somewhat wary, reasonably so, about the strength of the shifter as it sits right now.
I suppose I'll have to re-tool and try again some other time. Which is frustrating, because I feel like I did all the work required to install the JHM unit, only the stock shifter is still sitting in my car.
I just wanted to rant. Sorry if my post is a bit verbose."
