Results 1 to 8 of 8
    Dec 25 2006
    2012 A4 Avant Ti, 2014 Allroad
    Pinehurst
    Need some work done
    I have B5S4 brakes with calipers and rotors to put on and also a RNS-E unit that needs installing with a VAG coding for the DIS. PM me some prices. Thanks in advance. I'd hate to take it to the stealership and get ripped off, plus I want to help and learn with the install.
    Veteran Member Four Rings A4 Effort's Avatar
    May 28 2007
    '99 A4 2.8 / '07 A4 S-Line Avant / '09 A4 S-Line 2.0
    Mt. Airy, MD
    Re: Need some work done
    | 2007 Ibis Ti S-Line Avant | APR Stage 2+ | APR HPFP | 034 HFC | Forge DV | Stasis Exhaust | KW V1 Coilovers | SPC Adjustable Control Arms | 19" MRR GF6s | 034 TIP | 034 Sway Bar & End-Links | K&N Drop-In | Deval CF Front Splitter | Relak CF Sideskirts | S4 Recaros | TT-Sline MFSW | P3 Vent Gauge | RS4 Grille | RS4 Fog Grille Mod | RS4 Pedals | RS6 Shift Knob | OEM+
    Oct 29 2005
    10speed
    San Francisco, CA
    come to the meet. I can do your brakes there if you would like... Ill pm you
    - Clint
    Dec 25 2006
    Pinehurst
    Sounds good, I should be able to make it.
    Oct 29 2005
    10speed
    San Francisco, CA
    Quote Originally Posted by psteph2 View Post
    do you have new fluid? I suggest you get some (Around 3L to be safe) because there will be air in the lines. We can bleed all the brakes and clutch slave to make sure the new fluid is fully there
    - Clint
    Dec 25 2006
    Pinehurst
    I'll bring it, anything else you recommend?
    Oct 29 2005
    10speed
    San Francisco, CA
    are you doing anything to the rears?
    - Clint
    Dec 25 2006
    Pinehurst
    Just adding rotors and pads.
