    Veteran Member Four Rings A4_cabrio's Avatar
    Aug 09 2004
    2005.5 A4 2.0T
    Austin, TX
    Reload this Page Need help reading the engine logs
    Hey guys,
    My car has been very sluggish lately. Up to the point that I felt I needed to take some logs - especially boost logs but the numbers I am getting confused me.
    That's why I need your help.
    So I logged channels - 020, 034 and and 115
    I have a hard time interpreting the logs and I thought to start by sharing the boost logs maybe someone could tell me if the car is boosting right - I have APR93 and stock running and I would think right now the APR93 program is running.
    This is a small snippet from a power run from 1080 rpms to 6200
    I thought I was supposed to adjust for the atmospheric pressure but if I do that the idle boost is negative. If I dont - then the boost under load is huge - 26 psi
    Can someone please help me? One of my suspicions was that somehow I am running stock and not APR or something in the turbo system broke down.
    Engine | Engine | Boost Pressure Boost Pressure
    Speed | Load | (specified) (actual)
    % mbar mbar
    1080 18 340 990
    1040 18.8 330 990
    1040 18.8 360 990
    1000 30.8 540 990
    1120 48.1 820 990
    1440 66.9 1280 1000
    1840 80.5 1740 1070
    1960 85 1930 1190
    2080 91.7 1950 1290
    2160 99.2 1940 1380
    2400 109 1910 1510
    2680 127.1 1850 1720
    2920 148.1 1780 1880
    3080 143.6 1780 1820
    3280 140.6 1780 1800
    3480 139.1 1790 1790
    3680 137.6 1810 1790
    3920 139.1 1830 1800
    4120 143.6 1850 1800
    4320 143.6 1860 1820
    4600 148.1 1870 1830
    4800 147.4 1860 1820
    5080 145.1 1840 1790
    5320 143.6 1800 1780
    5560 141.4 1760 1740
    5760 137.6 1710 1710
    5960 136.1 1660 1680
    6200 133.1 1610 1640
    6280 89.5 710 1960
    2005.5 2.0T Tip Dolphin Grey / Black Interior
    Factory options: all except for Bose sound
    Added: 35% Tint, OEM Bluetooth, MFSW with paddle shifters, RS4 pedals, Brushed Aluminium mirror caps, S-line bumper, RS4 grille, Euro plate filler, 19" RS4 reps (Velocity), S4 valence, Satellite receiver, Quad tips, VMR boost gauge, AUX port
    Next mods: honeycomb fog grilles, LED DRL, Dension
    Aug 09 2004
    2005.5 A4 2.0T
    Austin, TX
    Re: Reload this Page Need help reading the engine logs
    Does anyone know what's the max psi on our stock program
    I always thought it was 12 PSI which is what I am making now - but the tuner just told me it was 8 PSI and APR only brings it up to 15. I thought APR would bring it up to 18 PSI.
    Veteran Member Four Rings eMacPaul's Avatar
    Jul 26 2008
    Marysville, WA
    Stock is 11-12, APR is bringing me up to 19.
    2007 A4 2.0T CVT Cabriolet S-Line Phantom Black
    APR, K&N air filter, Podi boost gauge, chrome-stripped grille, RS4 RSB
    Smoked side reflectors & markers, smartTOP, Eibach Pro-Kit, 12F/15R spacers, ER SMIC
    Xenon match DRLs, LED fogs, city w/ fogs, S4 mirrors, red LED interior, CC, 034 HFC + Magnaflow 14829
    Aug 09 2004
    2005.5 A4 2.0T
    Austin, TX
    ok. Thanks. It looks I was running stock - I switched to SLOT 2 - APR93 and I am showing 17-18 psi's now.
    I wonder if it would get any better with more time
    BTW: APR tech support was pretty nice - they pulled up my file and even told me which program was in slot 1 and which was in slot 2. Very nice and friendly service.
    Aug 09 2004
    2005.5 A4 2.0T
    Austin, TX
    So I changed the program I am running - chose slot 2 - and I think my car is running better - it seems to be boosting more - 17-18 PSI's in some cases though this snapshot below doesnt have more than a little over 16.
    Would a broken PCV prevent the turbo from boosting more?
    Engine Engine Boost Pressure Boost Pressure
    Speed Load (specified) (actual)
    % mbar mbar psi
    760 27.8 570 990 0
    760 39.8 1000 980 -0.145
    960 57.1 900 980 -0.145
    1320 54.1 860 990 0
    1520 60.2 930 1000 0.145
    1600 63.2 940 1020 0.435
    1680 63.2 900 1050 0.87
    1680 58.6 790 1080 1.305
    1600 48.9 670 1090 1.45
    1480 42.9 600 1080 1.305
    1320 41.4 570 1060 1.015
    1240 38.3 550 1050 0.87
    1200 38.3 550 1040 0.725
    1160 37.6 580 1030 0.58
    1160 37.6 590 1030 0.58
    1200 39.8 620 1020 0.435
    1240 43.6 680 1020 0.435
    1280 45.1 800 1020 0.435
    1400 54.1 880 1020 0.435
    1560 60.2 1020 1020 0.435
    1680 68.4 1020 1040 0.725
    1760 66.2 780 1080 1.305
    1720 54.9 760 1060 1.015
    1600 48.9 780 1050 0.87
    1520 48.1 760 1040 0.725
    1440 47.4 880 1030 0.58
    1480 58.6 950 1020 0.435
    1480 63.2 950 1020 0.435
    1520 65.4 950 1060 1.015
    1520 64.7 1190 1080 1.305
    1560 83.5 1570 1080 1.305
    1640 85.7 1680 1120 1.885
    1720 87.2 1750 1150 2.32
    1760 87.2 1790 1190 2.9
    1800 88.7 1950 1220 3.335
    1880 89.5 2180 1250 3.77
    1960 91 2320 1280 4.205
    2040 94.7 2310 1320 4.785
    2120 98.5 2310 1360 5.365
    2200 101.5 2300 1400 5.945
    2320 105.3 2310 1460 6.815
    2400 108.3 2310 1520 7.685
    2520 116.5 2310 1610 8.99
    2640 134.6 2300 1760 11.165
    2760 147.4 2290 1900 13.195
    2880 160.2 2250 2010 14.79
    3040 168.4 2210 2090 15.95
    3200 166.9 2210 2120 16.385
    3360 166.2 2200 2110 16.24
    3520 165.4 2190 2110 16.24
    3640 165.4 2190 2110 16.24
    3800 163.9 2180 2090 15.95
    3960 163.9 2180 2060 15.515
    4080 163.2 2170 2050 15.37
    4240 160.9 2160 2020 14.935
    4360 160.9 2150 2000 14.645
    4480 157.9 2140 1990 14.5
    4600 156.4 2120 1970 14.21
    4720 156.4 2110 1960 14.065
    4840 156.4 2090 1940 13.775
    4960 154.9 2070 1910 13.34
    5080 152.6 2050 1880 12.905
    5200 151.1 2030 1840 12.325
    5320 147.4 1990 1800 11.745
    5440 144.4 1970 1770 11.31
    5560 144.4 1950 1750 11.02
    5680 142.1 1910 1720 10.585
    5760 140.6 1890 1710 10.44
    5880 139.1 1860 1690 10.15
    5960 136.1 1840 1660 9.715
    6080 135.3 1820 1640 9.425
    6160 133.8 1800 1640 9.425
    6280 131.6 1770 1620 9.135
    6360 131.6 1760 1600 8.845
    6440 130.8 1740 1590 8.7
    6440 129.3 1740 1590 8.7
