Originally Posted by
B5A4Kevin
it is the same principle as the variable runner length intake manifolds on the 3.0, 4.2, and 2.0tfsi. longer, smaller diameter runners are best for low end torque while short, large diameter (aeb head and manifold) are much better suited for high rpm and cfm's (BT+).
Apples to oranges comparison...
Runner length and runner diameter are 2 different factors that come into play.The length is remaining the same in this scenario hence being the constant,it is just the diameter that we are changing.The intake valve diameter is not changing,neither the shape of the port @ the base of the head NOR the flow of air into the engine.
Now do not think I am here to put you down and say "whatever I say is gold so believe it" and I am not trying to sound like a dick but most of you are posting based on theories.I am trying my best to keep this conversation simple and straight to the point of answering the OP's questions.
Of course putting the AEB manifold on the small port cylinder head will hurt rather than help performance as you are introducing turbulence into the system.Turbulence that was not there before ,however,I allready stated back on page 1 the following.
Issam@034
Large port manifold + 034 phenolic spacer + small port cylinder head + 65mm DBC throttle body = 7-8whp gain
Hope that helps.
