Results 1 to 28 of 28
Thread: Misfires
    Veteran Member Four Rings Evilevo's Avatar
    May 26 2008
    2018 TTRS, 2014 Q5 TDI, 2020 Supra, 2022 F150, 2004 V70R
    MD
    Misfires
    I just logged my car and am noticing that i am getting ALOT of misfires on cyl5. I want to check my coils but not sure what i should do to check them. Move the coil around and see if the misfire follows it around?
    Veteran Member Four Rings Rated S's Avatar
    Apr 02 2007
    '01 S4 '94 D21
    Studio City, CA
    Re: Misfires
    Quote Originally Posted by Evilevo View Post
    That's the best and easiest way to check if its the coilpack.
    SoCalS4.com/Repair - For All Your Delicious B5 S4 Tuning/DIY Needs
    Don't like me? Feel free to email me and tell me all about it - [email protected]
    Veteran Member Three Rings seadoo4563's Avatar
    Aug 10 2007
    Annapolis,MD
    Re: Misfires
    hurry up an get here so i can fix yo car bitch ass. or at least tell you whats not wrong with it
    Veteran Member Four Rings tike0rz's Avatar
    Apr 17 2007
    B8 A5
    Re: Misfires
    I had the same problem a few weeks ago. TONS of Cyl5 misfires. My friend and I swapped out the injectors, coilpacks, and sparkplugs. Took 6 hours and the problem was still there. Baffled, my friend saw a light bulb, and realized it was one of the sensors near the top of the airbox, the ignition output power sensor, I think its called. Good luck!
    May 26 2008
    MD
    Re: Misfires
    yea, we moved the coil pack around. The misfire didnt follow it. We did a compression test. Came back fine. GOing to do a leak down test this weekend and also swap out the Ignition power thingys on the airbox.
    Jan 29 2007
    08 S4 00 S4
    MD
    Re: Misfires
    How'd the spark plug look out of that cylinder?
    08 S4- Stock SOLD
    May 26 2008
    MD
    Re: Misfires
    the spark plugs looked fine
    Active Member Three Rings panix73's Avatar
    Mar 17 2006
    Battleship Kruzer
    Long Island, NY
    Re: Misfires
    Check the ignition control module.
    Innovate.
    May 26 2008
    MD
    Re: Misfires
    Quote Originally Posted by panix73 View Post
    Where is that?
    Jan 29 2007
    08 S4 00 S4
    MD
    Re: Misfires
    On top of the air box. I think one black harness and one brown
    08 S4- Stock SOLD
    May 26 2008
    MD
    Re: Misfires
    Already checked those. Borrowed Aaron's and it didnt change. Im going to do a leakdown test and change my sparkplugs today
    Apr 02 2007
    '01 S4 '94 D21
    Studio City, CA
    Re: Misfires
    Do you happen to have 60lb injectors? Those cause misfires naturally.
    Veteran Member Four Rings Reich's Avatar
    Oct 14 2007
    2001 s4 ; 2001 jetta tdi
    Val-Belair
    Re: Misfires
    Quote Originally Posted by Rated S View Post
    Why do you say that? Do you run them? I also run them and Seems to missfire under load at high rpms. Changed icu's, plugs and about to buy coils.
    What do you guy's do to solve this?
    Apr 02 2007
    '01 S4 '94 D21
    Studio City, CA
    Re: Misfires
    Quote Originally Posted by Reich View Post
    I say that because I have 60# (630cc) injectors and they misfire at idle. I DON'T misfire under high load/boost/rpm, just idle.
    Oct 14 2007
    Val-Belair
    Re: Misfires
    Also have 630 siemens. But only missfire on all, p0300 under load high rpms. It's runing fine @ idle tho. I have an apointement with mike for finishing tune this Tuesday. The more i run her the more i believe it's a tuning issue. We shall see. Thank's for your input
    May 26 2008
    MD
    Re: Misfires
    Yes, i have the 630s. It only misfires at idle tho now. I changed out my plugs and that fixed the problem of it misfiring under load. Now i just need to figure out why it keeps pulling timing. I am going to try replacing my coils and ICUs
    Oct 29 2005
    10speed
    San Francisco, CA
    Re: Misfires
    what are you gapping the plugs at? Is it pulling timing on all cylinders or just 5?
    - Clint
    May 26 2008
    MD
    Re: Misfires
    it is pulling timing on all cylinders. Plugs are gapped at .024
    Senior Member Three Rings gaspeedracer's Avatar
    Jun 02 2007
    2001 Imola Yellow S4
    Daytona Beach, FL/Conyers, GA
    Re: Misfires
    maybe the MAF sensor is a good suspect to question.
    "A true leader has the confidence to stand alone, the courage to make tough decisions, and the compassion to listen to the needs of others. He does not set out to be a leader, but becomes one by the equality of his actions and the integrity of his intent."
    -Douglas McArthur
    Semper Fi!!!
    May 26 2008
    MD
    Re: Misfires
    Why would the MAF sensor cause timing to be pulled?
    May 26 2008
    MD
    Re: Misfires
    anyone?
    Jun 02 2007
    Re: Misfires
    well if the MAF is fucked up, its not sending the right info to the ecu for it to send the right amount of fuel to the cylinders i.e. air/fuel ratio. just my 2 cents so hopefully someone more experienced can chime in.
    -Douglas McArthur
    Semper Fi!!!
    May 26 2008
    MD
    Re: Misfires
    hmm, These cars can run without the MAF sensor plugged in correct? Maybe I'll try reseting the ECU and than running the car without the MAF.
    Jun 02 2007
    Re: Misfires
    i know that these car can run without the MAF but not sure if your idea will work. but who knows? try it out and see if it does. it beats dropping a hundred on a new MAF sensor. good luck!!!
    -Douglas McArthur
    Semper Fi!!!
    Oct 22 2008
    United States - DE
    Re: Misfires
    Detonation.
    How much boost are you running and on what kind of fuel? What are you using to tune?
    Usually when a car pulls timing it is because it is knocking.
    May 26 2008
    MD
    Re: Misfires
    really? Thank you, i never would have thought that detonation would cause a car to pull timing.
    The way it is pulling timing is because of something else. If it was truly pulling timing because of detonation, it would do it on the first pull after reseting the ECU. but it doesnt. And it also pulls timing at like 2psi or less, and than i let off and get back on it, and it is fine.
    Car is running 22psi and on 93oct.
    Veteran Member Four Rings CONTROL ONE's Avatar
    Sep 19 2008
    2014 BMW M235i 6MT, 2010 Audi S4 6MT
    Toronto, Canada
    Re: Misfires
    What block were you measuring to determine the misfires? My car keeps pulling misfire codes but not enough to actually set off the CEL.
    I'd love to be able to actually log a drive with my car using my vag-com to see what's going on.
    Thanks.
    May 26 2008
    MD
    Re: Misfires
    Quote Originally Posted by CONTROL ONE View Post
    Thanks.
    I dont remember what block it was. I just kept going thru the vagcom till i found it.
    I changed my plugs and the Misfires went away
