Results 1 to 11 of 11
Thread: Aux Fan -
    Jul 11 2007
    Chicago
    Aux Fan -
    Is there a temp you can change the Aux fan (Electric Fan behind the radiator) to turn on or off at?
    in Vag of course...
    I am overheating just a bit after a Timing belt job. in Vag it will be up to 102c no more and thats in traffic (bumper to bumper for 45 minutes) on a 65 degree day.
    I am FMIC, I've had the fmic installed for over a year now, I had not experienced this during that time. again this only happened after the timing belt job. I did the TB job and its good I think.
    I checked the tensioner and it seems to be fine no problems. I bleed the coolant system all to no avail.
    What I did notice is that when I turn on the heat (at speed doesnt matter) it cools down the engine with noticable difference. Vag shows at 98c thats a 4 degree difference.
    Old "Casa - 01 S4 - Homebrew Stage X - K03/16 - FMIC - Autospeed Motor Mounts/Tranny Mounts/DTS - Stern Power Ring/Rear Differential Poly - XS Power Exhaust - JHM Shifter/Solid Link/Delrin/3rd Detent/Homebrew Shifter Knobbie weight - Homebrew SMOC -"
    New "07 Infiniti Black Sedan G35s 6MT"
    Veteran Member Four Rings Evilevo's Avatar
    May 26 2008
    2018 TTRS, 2014 Q5 TDI, 2020 Supra, 2022 F150, 2004 V70R
    MD
    Re: Aux Fan -
    That is because when you turn the heat on, it takes heat from the motor. Same reason why if you bust your headgasket and the car is overheating, if you need to get it somewhere, drive with all the windows down and the heat blasting.
    Jul 11 2007
    Chicago
    Re: Aux Fan -
    EvilEvo - Its the electric fan in front of the radiator that is doing the majority of the cooling not the inside fan. I do however agree it will help but not significantly.
    But do you know of anyway to kick on the fan at certain temps?
    Jun 14 2007
    2000 S4
    Connecticut
    Re: Aux Fan -
    Quote Originally Posted by S4-Casa View Post
    there is a lower than stock temp afterrun fan switch that you can purchase from ECS tuning or some other places. I have it, it basically turns the fans on at 198* rather than 240 something that it does from factory...
    it may also have to do with the tstat that you bought... if you see ECS lists a few different ones. I dont understand them but heres a link lol
    http://www.ecstuning.com/stage/edpd/...ategory=Engine
    Jul 11 2007
    Chicago
    Re: Aux Fan -
    No the after run switch was replaced a while ago but thats for after the motor has been shut down... I think you are correct though about the different listings of the t-stat...CRAP ! I have to take the whole thing apart again to fix... ! DAMN !
    Jun 14 2007
    2000 S4
    Connecticut
    Re: Aux Fan -
    that sucks... call up ECS see if one of those guys can explain the differences, id be interested to know as well !
    Account Terminated Four Rings
    Mar 14 2007
    michigan
    Re: Aux Fan -
    or u can by a 2 dollar switch and turn it on in the car at any time u wish.
    Jul 11 2007
    Chicago
    Re: Aux Fan -
    I am thinking to just do it all over again with a new t-stat.. TB job is relatively easy.
    Hoping to shoot under 5 hours this time..
    Jul 11 2007
    Chicago
    Re: Aux Fan -
    Just confirmed last night the t-stat was at 92c not the stock 87... GOOD CALL AudiSportB5S4 !
    Jun 14 2007
    2000 S4
    Connecticut
    Re: Aux Fan -
    E-points for me !
    so whats the difference ? like, if you got a cooler one is it better or worse for the car than stock or is stock what you want in this type of thing ?
    Veteran Member Four Rings haus4's Avatar
    Apr 27 2008
    silver s4
    LI
    Re: Aux Fan -
    it just depends at wat temperature the t-stat opens, a higher value for the t-stat the warmer your engine will get b4 it opens to let the coolant flow. In this case, that is why hes reading 104C, a little higher than normal, bc of the 92C t-stat
