Results 1 to 3 of 3
    Jul 23 2008
    Pasadena & San Diego
    Concours Finish Detailed: Black Mercedez SL600
    Mercedez Benz SL600
    Wheels, Wells & Tires
    P21s Wheel Gel Cleaner
    Meguiars APC +
    Jet Seal 109 to seal wheels
    Various Brushes and Foam Tip Swabs
    Megs Hyperdressing Tire Shine
    Exterior Wash
    P21S Total Auto Wash Pre-soak
    Chemical Guys Citrus Wash & Gloss
    Clay
    Chemical Guys Blue Clay
    ONR used as Clay Lube
    Paint Correction
    LC Purple Foamed Wool with Menz SIP
    LC Orange Pad with Menz SIP
    LC White Pad with Menz PO106FF
    Trim
    Black Wow
    303 Aerospace Protectant
    Prima Clarity Glass Cleaner
    Glass Polishing Cloth
    Meguiars NXT All Metal Polish
    Interior
    Prima Nero
    303 Fabric Guard
    Prima Nourish Leather Conditioner
    LSP
    Chemical Guys Jet Seal 109
    Chemical Guys 50/50
    Equipment
    5.5 Hp Rigid Shop Vac
    Karcher Electric Pressure Washer
    Cam Spray Foam Cannon
    Makita 9227c
    Porter Cable 7424
    LC 6.5" pads & 4" pads
    Thought I'd take a photo of most of the products used
    Before Photos
    Car looks good in the shade from afar......
    But in the sun close up you get.....
    Foam Tipped Swabs from AutoGeek. Great for calipers, lug nuts, and other small hard to reach areas.
    Can't forget behind the wheels...
    Prepped for Trunk 50/50
    Before
    After
    I always like taking the car outside under the sun to take 50/50s because the sun shows the defects best......
    Up Close
    Can you tell I like 50/50s ???
    Closer
    Jul 23 2008
    Re: Concours Finish Detailed: Black Mercedez SL600
    Fender 50/50
    Before
    After
    Before
    After
    50/50
    Afters
    As Always, Thanks for Looking.
    Veteran Member Three Rings Dowskeet's Avatar
    Aug 10 2007
    Did you use the Chemical guys citrus wash for the sud sud soak?
    Looks great.. 50/50 really show how much you fixed. Great job!
