Results 1 to 22 of 22
    Veteran Member Four Rings Klum00's Avatar
    Nov 27 2006
    Baltimore, MD
    S4 died last night while driving, confirming it's the alternator...
    I’m going home on 695 and accelerate to pass a car. I hear some sort of noise (a popping almost) and loose acceleration instantly. First thought is that I blew a turbo, but then I look down and my brake, traction control and battery lights are on. I’m close to an exit so I get off the highway as soon as possible. As I’m exiting I notice that my power steering is starting to go on me, power braking as well. Basically I get the car to the end of ramp which dumps off into a residential area and turn it off.
    My battery is still showing a bit over 12volts with all the lights and radio working find in the car. Problem is it won’t start, or even attempt to. I turn the ignition to fire it up and get absolutely nothing. This was at night and working with a maglite from what I can tell the accessory belt looks fine.
    I’m thinking that the alternator is toast but have a few questions. Can you “blow” an alternator with the extra power needed for acceleration? Also I’d think that the car would try and start off the battery, meaning it would crank just not stay on for very long? Maybe the pulley on the alternator is frozen which is preventing the accessory belt from turning? I also put in a front mount intercooler this weekend, but have driven the car a solid 100+ miles since this incident, so I’m doubting it caused anything and this is just a shitty coincidence.
    Can anyone confirm that this is my alternator before I go buy one. I’d get out there with a volt meter to check, but the car is a good 20 mins away and I have no ride at the moment.
    Quattro Kings
    @quattroking
    Currently in the garages
    2016 S6 . 2014 RS5 cab . 2013 Q5 . 2008 A6 avant
    2002 TT ALMS . 2001 S4 . 1992 UrS4 . 1974 100 LS
    1952 DKW RT125 . 1939 DKW F8 . 1937 DKW F7
    Oct 31 2005
    Ashburn
    Re: S4 died last night while driving, confirming it's the alternator...
    Aaron, i think you
    Blew an intercooler hose was my first guess but after reading more....I hate to say it but it sounds like a timing belt issue just from how you describe it and from my personal experience.
    hope it just an alternator. When mine went it wouldn't crank either i had to but a new battery and alternator
    goodluck, and report back your findings.
    - Instagram: @Sinister_rs5-
    Veteran Member Four Rings audimeister's Avatar
    Jan 05 2006
    '07 A4 Avant S line Ti 6MT Quattro
    Oakland, CA
    Doesn't sound like bad alternator. Never had one in an S4, but in other cars the alternator goes, then the car runs on battery until that dies.
    "Obsessed" is a word that the lazy use to describe the committed.
    Nov 27 2006
    Baltimore, MD
    yeah that had crossed my mind too, but i'm praying that's not the case...
    Quattro Kings
    @quattroking
    Veteran Member Three Rings seadoo4563's Avatar
    Aug 10 2007
    Annapolis,MD
    how far are you from my shop? im on rt40 in catonsville. ill can test the battery an alt real quick for you so you can rule that out if its not. or come borrow my jump box and see if you can get it to start
    Oct 31 2005
    Ashburn
    when you heard the pop did the car jerk at all or did you feel the pop when it happened?
    Nov 27 2006
    Baltimore, MD
    Ben, its on leeds road, just off of washington (rt 1), i was coming from my buddies place off of 40. I might do that actually, PM me your phone number if you don't mind...
    Vern, I don't remember any kind of jerk more just heard it and then wasn't accelerating. I'm hoping this means I popped an intercooler hose, but i don't see where the dying power steering and braking comes in...
    Quattro Kings
    @quattroking
    Aug 10 2007
    Annapolis,MD
    ok sent. gimme a call ill be in the shop till 5 so anytime until then is cool
    Oct 31 2005
    Ashburn
    intercooler hose wouldn't cause the last part to happen, so i'm keeping my fingers crossed for you.
    alternator FTW
    Nov 27 2006
    Baltimore, MD
    actually val said her ex had the same problem and it was a hose, i'm gonna borrow a car right now to see if i can figure it out...
    Quattro Kings
    @quattroking
    Registered Member Two Rings
    May 07 2008
    98' Jetta GLX, 68' Coronet
    Dalton Oh,
    Now I'm relatively new to S4's but with my experience with the alternator on my Jetta, when it died it never popped and you could still at least hear the starter click and none of the electronics would work since the battery was dead. It doesn't really sound like an alternator issue but lets just hope your timing belt didn't break or jump.
    Veteran Member Three Rings 2k1audiS4's Avatar
    Oct 30 2007
    Pasadena, MD
    My serpentine belt blew off the week before H2O and I could still start and drive the car(my battery light came on as well). I drove it 20 mile to induktion. If a pully seized up I would think it would have schreded your serp belt. Sounds like one of three things:
    -Your power sterring pump seized causing you to loose power sterring and stopping your serp belt from working causing the battery light to come on
    -your starter sezied
    -your t-belt blew
    A family freind of ours has a repair/towing company right by crazy rays in b-more. he has a roll back if you want me to call him he would probably give you good rate. Give me a ring at 443-618-7638 if you want me to make the call. GL man
    2001.5 S4 Silver 6MT......GIAC X, APR Bi-Pipe, FMIC, "Custom" UUC VM1, RS4 Clutch, APR R1 DV's, AWE DTS, K&N, Eibach pro kit, D3........SOLD
    2000 S4 Black 6MT.....Stock........SOLD
    2000 A6 2.7T 6MT.....Stock..... SOLD
    2001 S4 Sport Black 6MT.....Stock......SOLD
    2001.5 S4 Santorin 6MT....Stg2.....SOLD
    2001.5 S4 Sport Santorin 6MT....Stg2....SOLD
    2001 S4 Sport Silver 6MT.....Stg1....ACCIDENT THEN SOLD
    Veteran Member Four Rings Evilevo's Avatar
    May 26 2008
    2018 TTRS, 2014 Q5 TDI, 2020 Supra, 2022 F150, 2004 V70R
    MD
    As i said on AD. Check all your intercooler hoses. Ants lower pipe blew off and the car completely shut off. And wouldnt idle after that.
    Jun 01 2008
    Apopka, FL
    if it were your altenator you'd have a dead battery after that little bit of driving, when the alt in my 1.8l protege blew it killed a red top optima battery in about 1 1/2 minuites and that was just slow driving in by neighborhood.
    Aug 10 2007
    Annapolis,MD
    i want to rule out IC piping because he said it wont even start. ive blown IC pipes before an it starts but kills out an idles horrible. his car is not even tryin to start
    Nov 27 2006
    Baltimore, MD
    problem solved!
    it was the intercooler hose after all. I'm thinking i blew it enough that it was basically a wide open hole, so this shut the car off. That could have been why no power steering or braking. I'm still baffled why it wouldn't even turn over. I do have a 2001.5 so maybe they built in some pre-cautionary cut off. I found the hose easily tightened everything back up and she's running like a charm.
    Thanks for all the quick advice and idea's guys, much appreciated!
    Quattro Kings
    @quattroking
    May 26 2008
    MD
    Told ya ;)
    Aaron, Text me or PM your number, I lost it......
    Oct 31 2005
    Ashburn
    Glad to hear the good news and not another S4 horror story
    Nov 27 2006
    Baltimore, MD
    me too.
    not gonna lie, i was a bit scurrrrrred
    Quattro Kings
    @quattroking
    Oct 30 2007
    Pasadena, MD
    Ahhhh the only good news I think I've heard all day. Good to hear man.
    Senior Member Two Rings ChrisS4's Avatar
    Jan 14 2008
    2001 S4, Ducati 848
    Colorado
    Yea i actually had the exact some problem a few months back but i was relieved to see it was only an IC pipe lol
    Active Member Four Rings FrimmelNoJerz's Avatar
    Sep 21 2006
    Norjerz
    sounds familiar...
    SBSC
    I also like to live dangerously.
