Results 1 to 7 of 7
    Veteran Member Three Rings A4p's Avatar
    Mar 06 2006
    Audi 1.8TQM6 S-line USP 2004
    Sweden
    Sparkplug Injectors Coilpack
    anoyone please tell me what is what
    USP CLUB MEMBER 861
    Rev0 stage I file - 300+ bosch injector - OFE SS - APR Snub mount - Nitrogen - RS4 Swaybar - K&N air filter - **-
    Veteran Member Four Rings kwimberly's Avatar
    May 03 2008
    Orlando
    Re: Sparkplug Injectors Coilpack
    sparkplug - goes in the 12v socket next to the parking brake - they used to put cigarette lighters in these plugs. The sparkplug keeps blowback sparks from flying out of the socket.
    injectors - these are in the sweet OEM first aid kit that is usually found in the rear center armrest. If you are stranded on the highway and get bit by a snake, use the injectors to counteract the poison.
    coilpack - this isn't actually a part. It's the technical term for how Audi packs the airbags. The coilpack method coils the airbag into place so that when it deploys it spins out like a fluffy soft propeller.
    Kevin W.
    2003 A4 1.8T quattro 5-spd. | USP lower | APR ECU w/ TT225's | APR TIP | test pipe | FMIC | Apikol snub | ecodes | Podi® | AWE sport pedals | JHM SSK/linkage | Forge 007 DV | '02 OEM sport suspension | OEM sport wheels | B6 S4 brakes w/ TyrolSport stiffeners | RS4 rear sway bar| Magnaflow 14829's| AVIC F700BT | hard-wired Passport 9500 | Side-mount trash bag hanging from shifter
    Senior Member Three Rings ThreePointOhh's Avatar
    Dec 24 2007
    |2004 A4 3.0Q 6SPD MT|
    New York, NY
    that wasnt nice...
    ** I'm Gonna Drive it Till the Rings Fall OFF!! **
    May 03 2008
    Orlando
    I thought the OP was joking. Registered for 2.5 years. USP. If it wasn't a joke then I'll remove my post. Seriously.
    Kevin W.
    Mar 06 2006
    Sweden
    Quote Originally Posted by kwimberly View Post
    it wasnt a joke .
    also if anyone could tell me what they do, because, they all sounds the same, yes you heard it clearly spark plug injectors coilpack, in my mind they all sounds the same. that is why i posted this theard so you guys could tell me what is what, and wtf are they located. okay i was looking at a4mods, and i see injectors are located in the manifold wth??. sparkplug are located in the engine??. where is the coilpack??.. loool
    USP CLUB MEMBER 861
    Veteran Member Four Rings BOPOH's Avatar
    Oct 08 2007
    Columbus, OH
    im surprised you haven't find out THE HARD WAY what are these damn coilpacks are.
    COILPACKS - things that send electric power to SPARK PLUGS - that ignite your fuel in cylinders, which is provided by FUEL INJECTORS
    All of it located under plastic engine cover
    Veteran Member Three Rings nihil's Avatar
    Oct 01 2007
    Too small
    N/A
    2002 A4 1.8TQMS (sold)
    1982 MB Geländewagen 300GD
    1968 Charger R/T
    1987 Porsche 944 (sold)
    2015 Tacoma TRD/OR
    2007 4Runner
    2022 Tenere700
    2009 TW200
