I first noticed this boost problem after I switched out my 710N diverter valve for a new one from ECS Tuning. It seems to stutter in any gear after third above 4k rpms after I go WOT starting in first. Once it gets up there, the boost will actually "stutter". It also sounds like the engine bogs a little bit when the boost jumps down.
Here's a nice video to show you what happens. I had to edit the video because I took it at night.
In the video the first few seconds is my car still in second gear. Then once it goes into vacuum and jumps back up, that's when I'm in third gear. It spikes to 17 psi and then tapers down to 14 psi then it starts doing the jumps between that and 9 psi.
Does anyone have the slightest idea what's happening and how to fix it? My mods are below if that helps a bit.
