Results 1 to 16 of 16
    Veteran Member Four Rings G Men 08's Avatar
    Feb 05 2008
    One trick pony at the time.
    Waterloo NY
    headlight washers
    they quit working on me.. damn car, two problems in one week.. not big problems lol but still... the passenger rear window switch on the drivers door wont let me roll the window down unless i do the one touch all the way down feature any clues on either?
    B6 A4 3.0-sold
    C5 A6 4.2-sold
    C4 A6 2.8-sold
    B5 S4 A few mods-SOLD thankfully!!
    MKIV Golf TDI- SOLD MPG were amazing but other than that...
    C5 allroad 2.7 auto
    Veteran Member Four Rings Boosted3.0's Avatar
    Jul 27 2008
    02 A4 3.0, 08 M5 5.0
    Miami, FL
    Re: headlight washers
    What do you mean the washers quit working? They don't pop up? Check the fuse first and if that isn't it your probably going to replace them...which sucks because you have to take the bumper off. So if your lowers are unpainted...live with it untill you are ready to paint then tackle it all at once....that's what I'm doing at least. Window switch I have no idea, your most likely going to have to go to audi for that or live with it.
    High speed Ferrari movement...
    Oct 31 2006
    San Antonio, TX
    ^^^^ On the right track, but you probably don't need to replace the nozzles
    1- check the fuse, it might be blown. If it is you're lucky this is an easy fix.
    2- if the fuse is fine, you probably have a bad pump. This takes a little work but can be done in under an hour. This is the fix I did and mine have been working fine since. You can pick up the pump at the dealership, it's not too expensive. There is a write up on how to do this fix on here or Audiworld. Do a search and I'm sure you'll find it.
    Current: 2016 S6 Previous: 2015 A6, 2012 Q7 Prestige SLine, 2005 S4, 2007 Avant 2.0T, 2002 A4 1.8T
    Senior Member Three Rings G-Bus's Avatar
    Aug 25 2008
    Montreal, Canada
    which fuse is it exactly?
    Veteran Member Four Rings jackyaudi's Avatar
    Jun 26 2007
    '02 A4 1.8TQS
    Montreal
    I had the same issue a while ago. My pump was gone, replaced by dealer under warranty. For the window button, did you try unplugging the battery for like 5 min and retrying again? If that does not help, you could check the wires for the rear window unless its a programming thing. Best thing is to wait till you have more serious stuff going wrong and add these two issues to the list when u go next time to the dealer..to make the $100 deductible worth it. I go there with at least $3000 bucks of repairs, and sometimes I get away without paying any deductible.
    For your OEM HID D1S/D2S/D3S and HID conversion [Headlights/Foglights], and Interior/Exterior LED needs, send me a PM.
    Stuff F.S: http://www.audizine.com/classifieds/...4-parts&cat=21
    Oct 31 2006
    San Antonio, TX
    Quote Originally Posted by G-Bus View Post
    Check your owners manual
    Oct 06 2008
    Los Angeles, CA
    I don't even know how to work my headlight washers hahahahhahahaa pretty sad
    Oct 31 2006
    San Antonio, TX
    Quote Originally Posted by R3K8C24 View Post
    They pop up when you wash your windshield, IF the headlights are on. If the lights are off, they don't pop up.
    Aug 25 2008
    Montreal, Canada
    mine never pop up! :(
    Oct 06 2008
    Los Angeles, CA
    I'm gonna try it out tomorrow and see if mine work. Thx for the info!
    Senior Member Three Rings BLACKa4QUAT's Avatar
    Mar 26 2008
    union city, ca/fort worth, tx
    heh in my b6 i blew the fuse to my headlight washers, the fuse looked fine, but a fuse tester said it was bad, replaced the fuse, and it worked again.
    2006 A4 2.0Tqm, S-line, tech, FH-P8000BT, 10" sub, 800 watt,
    VAG-COM mods (remote windows, no chime), revo stg 1 tweaked
    AWE pedals, HRS4 DTMs/Eagle GT, VMR TP
    193.7 awhp/232 ft/lb/91 oct pre-TP
    16MAR09DSWHTAW
    Senior Member Three Rings 04_A4_1.8T's Avatar
    Apr 13 2008
    04 Audi A4 1.8T
    Utah
    i had the same problem with my windows in my car... took it to the dealer and they said it was the window regulator switch... took them about 5 min to replace it... under warrenty though dunno how much it would be if it wasnt... maybe there is a diy for that switch somewhere and you can just buy the part
    Registered Member Two Rings monkey323i's Avatar
    Apr 15 2008
    cke
    headlight washer pump -> $50 USDs
    labour time -> 1-1.5 hours.
    3 reasons why it doesnt pop out:
    - Cracked/Leaky headlight washer pump.
    - leaky fluid line that goes to front pumper nozzle
    - blown fuse.
    If you dont find any washerfluid leak, the most likely it's blown fuse.
    Feb 05 2008
    Waterloo NY
    yepp^^ i noticed a washer fluid leak a few weeks ago, just didnt really think anything of it cause it went away... that sucks, oh well.. ill still check the fuse, and if thats fine then im not too worried about it, the only thing i use it for is when people ask what the boxes on the bumper lol.. thanks guys
    B6 A4 3.0-sold
    C5 A6 4.2-sold
    C4 A6 2.8-sold
    C5 allroad 2.7 auto
    Veteran Member Four Rings jonan's Avatar
    Nov 25 2006
    2X B7 RS4 - STG III B6 A4 (gone, but still in the family) - Mini R56 S - '15 Macan S - 997.1
    Austin, TX
    i had this problem a month ago, i blew 10+ 25A fuses, i forgot who it was, but they recommended using a 35A fuse instead of a 25A and my fuse hasn't blown since.
    Oct 31 2006
    San Antonio, TX
    Probably a blown fuse or bad pump.
