Results 1 to 6 of 6
    Veteran Member Three Rings GetAwayFromMe's Avatar
    Jan 03 2008
    One million dollars all in pennies
    Iowa
    Best way to clean exhaust after turbo failure
    Just like the title states, what do you guys use to clean the exhasts after turbo failure and all the oil that inside. Lot's of brake cleaner?? Just run it out?
    I'll be pulling my motor out in a week or so and need to find out. I will be doing my clutch and gutting my cats at the same time.
    Veteran Member Four Rings AudiTechS4's Avatar
    Oct 19 2007
    2000 S4
    Scottsdale , Az
    Re: Best way to clean exhaust after turbo failure
    run it out i wouldn't be spraying brake clean into my cats so just burn it out
    2001 Audi S4 Manual - Nogaro Blue/black - Full AWE stg 3 kit w/ manifolds,h&r coilovers,jhm trans rebuild,UUC VM3 exhaust , 2.5" dp's - Needs Love - Got some love now 442awhp and 512 awtq
    2004 Audi S4 Avant manual - Silver/black - 2.7 swapped ,k24's and srm side mounts
    Apr 18 2007
    b5 s4 nogaro , 1991 bmw 325is 5spd
    florida,wellington & hollywood
    that sucks man oil got on my secondary cat and destroyed it .. ended up riding no cats :) gotta love fl
    cheers
    --daniel
    Aug 06 2008
    Canadia
    after i did a boost leak test and got a bunch of oil into my exhaust, i found lots of redline driving did the trick of cleaning it out.
    Veteran Member Three Rings Grangalan's Avatar
    Sep 27 2007
    Stage III 2001.5 S4
    Clearwater, FL
    i had my drivers side exhaust impellar and shaft snap off and dump about a quart of oil into my pipes. Just went stage III and still smoking after a week. Only when the exhaust is hot and when im at a light somewhere. My guess being when i stop some of the oil swishes forward a little onto the hotter piping
    is a week.. or 200 miles of in city mild driving too long to burn off a quart of oil? lol...
    --Black 2001.5 -S4- 10secS4 Tuned
    Jan 03 2008
    Iowa
    I'll just ride it out than. i cant really be redlining because of the new clutch that needs to be broken in. I'm not sure which turbo went out but most than likley it's the drivers side because it's been making noise for a while now and last night it just blew. It's pretty bad because there was oil dripping out of the exhaust tips and it was smoking like a train.
    For now i'll buy some used turbos in good condition that can last me untill summer so i can save up for an upgrade. I don't mind the labor since i work as a mechanic and have a lift and all the tolls for the job.
