Originally Posted by
covertS4driver
Audi should recall this... so many people have had this same problem!
Audi issued a TSB on this problem, the info describes the cause and details the remedy including part numbers for updated hinges and a part number for just the gb door.
Technical Service Bulletin
Glove compartment opens slowly
68 07 01 March 19, 2007, 2012801/2. Supersedes Technical Service Bulletin Group 68 number 06-01 dated Aug. 28, 2006 due to inclusion of additional models.
Model(s)
Year
VIN Range
Vehicle-Specific Equipment
A3
2005 – 2006
All
Not Applicable
A4
2002 – 2006
All
A4 Cabriolet
2003 – 2006
All
A8
2003 – 2006
All
Improved brake element (damper) and reinforced glove compartment cover hinges from model year 2007. Improved brake element (damper) is identified as version 09S or higher. Only improved parts are available.
The improved brake element is version 09S
Service
If the glove compartment door opens slowly, replace the brake element (damper). If the glove compartment hinges are broken and the glove compartment cover is available separately (A4, A4 Cabriolet, A8), replace the glove compartment cover only. The A3 glove compartment is only available as an assembly and will need to be replaced as such. In either case, also replace the brake element (damper) if the version is lower than 09S at this time. For this condition do not replace the glove compartment cover without replacing the brake element
Required Parts and Tools Part Number
Part Description
Quantity
8E1 880 324
Brake element with switch (A3).
1
8E1 880 324A
Brake element with switch (A4, Cabriolet, A8).
1
