Results 1 to 7 of 7
    Registered Member Two Rings
    Jul 16 2008
    2001 Audi A4 2.8L Quattro
    Chesterfield, Virginia
    Turbo Question??????
    Is it possible to turbo an 2.8 because a friend of mine said you can turbo any car.
    Apr 22 2007
    Riverbank, Ca
    Re: Turbo Question??????
    Physically, you can add a turbo to any car. Yes.
    It takes time an money.
    Veteran Member Four Rings pipe7284's Avatar
    Sep 14 2006
    `07 Audi A4 S-Line 6MT Quattro | '01 Audi S4 AVANT 6spd
    Lansing, MI
    Yes you can. and it has been done before to a b5 A4 2.8. they actually did a rear mounted turbo on the 2.8 motor.
    '01 Audi S4 6spd Black AVANT DAZ E85 Tune Frankenturbo F21s / 034 RS4 inlets / BOSCH EV4 72# injectors / Walbro 450L fuel pump / Daz 89mm maf housing / AFE Intake Cone / SRM SMICs / 034 street density trans and motor mounts / SSAC downpipes / Vibrant catback exhaust / H&R Ultra Low Coilovers / 18x9.5 Rota Grids / 17z Brembo front BBK / 034 Rear BBK / JHM Short shifter / JHM stg 3 clutch / PODI Boost gauge / [/CENTER]
    SOLD
    Veteran Member Four Rings GURUMAN's Avatar
    Mar 13 2007
    2.9L PTE 6766 1000 Bhp single Monster !
    Montreal
    Actually you could buy a used s4 kit and slap it on
    Manifolds, turbos, downpipes are bolt on on a 2.8L
    intercooler and oil and coolant pluming could be custom at a resonable cost, only fuel management will be needed.
    I'm sure with heaty k03 that you could run stronger than a supercharger.
    GURU energy drinks
    www.guruenergy.com
    10.58 @ 140.17 mph
    10.51 @ 137.56 mph
    http://www.youtube.com/watch?v=1kG98vSWkT4
    WATERFEST 15 RUN 10.92 @ 133.55 mph
    Veteran Member Four Rings haus4's Avatar
    Apr 27 2008
    silver s4
    LI
    damnit u guys beat me to the post,
    i was gona say u can turbo anything, like this
    http://www.youtube.com/watch?v=TNMlzW_1MLg
    or you could just buy a turboed car already and not have the hassle
    Jul 16 2008
    Thanks alot guys, this helps.
    Veteran Member Four Rings B5A4Kevin's Avatar
    Apr 06 2008
    Brandon, FL
    it is possible although it would be pointless imo. the 2.7 is a 2.8 block with reinforced sleeves for higher boost. thats why it lost .1Liter. plus the swap car is most likely automatic, and standard suspension and maybe even frontrash. so even if you swapped in a 2.7 or turbo'd the 2.8 it still wouldnt hold a candle to a stock s4. if you are gonna do it, do it right and go vr6t or 4.2L.
    Current whip:
    99.5 A4 1.8T quattro Sport.
    RIP:
    Brilliant Black 06 A3 2.0T 6-spd
    Brilliant Black 01 A4 1.8T QMS
    Pearl White 99 A4 1.8t QMS
