1. Hello guys I just recently had my avic d3 installed at Best buy. I'm going back on Friday because the bluetooth doesn't work. The wiring seems to be right according to the guy and the unit does make the call but I cant here anything when the call has been made. Any suggestions as to what is wrong?
2. Also, I was researching here about powering the unit w/o ignition. With our old symphony radio when the key is in the off position the radio still works. But with this unit the radio only works when the key is in the on position or when you start the car. The guy said he wired it like that because if he wired the red wire on the constant position then the system will be on every time and it will drain my battery. He said the avic d3 even when its off the screen is still on. If the red wire was wired on the constant position would the unit still be on even if the key wasnt on the ignition? I want the unit to act like the symphony. When its the key is in the off position I can still listen to my radio. With this unit I have to turn the car on or start the car to listen to my radio. It bothers me because at night if I want to listen to the radio without starting my car I cant. And If I turn on the car my drl lights will always on.
3. I want to know For ppl that have the avic d3 on their audi, when the ignition is in the off position and the key still in the ignition, are you able to still listen to your radio? When the key is out of the ignition will your unit still stay on?
