Results 1 to 8 of 8
Thread: Rotor?
    Active Member Four Rings Goped220's Avatar
    Feb 16 2006
    2023 Audi S4, 2023 Audi A4 & 2016 Subaru Crosstrek
    NY/FL
    Rotor?
    What rotor is better and why Slotted/Cross-Drilled Rotor or just Slotted rotors?
    Previous:
    2006 Audi A4 Stage 3 6-Spd, 2011 Audi S4 6-Spd, 2016 Audi S4 6-Spd, 2017 Audi A4 6-Spd Stage 2, 2019 Audi S4 Stage 1, 2019 Benz E450 Stage 1, 2015 STI, 2013 370Z, 2013 Benz GLK, 2014 F-150 FX-4, 2020 Lexus GS350 F-Sport
    Veteran Member Four Rings vtracer20's Avatar
    Apr 14 2008
    Milton VT
    Re: Rotor?
    from what i heard crossed drilled tend to break. i would go with blanks, more surface area and a more aggressive pad
    2007 A4 S-Line / Ti Pkg / Quattro / Bilstein Pss9 / JHM Short shifter / GIAC X+ chip / RS4 rear sway bar / 20% rear tint / 10mm front 15mm rear spacers / Forge DV / DTM CF replica rear lip spoiler / DTH CF roof spoiler / Cupra R front spoiler (not on) / Infinity BasslinkII sub
    looking for: CF front lip / S4 alum mirror hosing
    Veteran Member Four Rings redhott06's Avatar
    Mar 15 2007
    2006 A4 2.0t
    Bedford, NY
    Re: Rotor?
    i heard slotted will eat away at your pads, but i could be wrong on that.
    im on my second set of zimmerman cross drilled fronts, no cross drilled in the back, and i love them.
    06 Brilliant Red A4 2.0T stage2+
    sparco, bbs, revo, stasis
    [email protected]
    Veteran Member Four Rings 1997gtx's Avatar
    Sep 14 2006
    14 GLI
    Re: Rotor?
    You'll want to stick to dimpled, IMO.
    Dimpled are better than drilled because you retain the rigidity of the rotor, while getting good heat dispersment from the dimlpes.
    If you want even more agressive breaking, go for slotted as well.
    --Adam
    Have questions? E-mail me.
    Registered Member Two Rings Laurence@GsG's Avatar
    Jul 25 2008
    Audi S5, Z06, Supra
    Corona
    Re: Rotor?
    Quote Originally Posted by Goped220 View Post
    Not all Rotors are made the same. Must cheap rotors are made in china. Some are made in Canada. Then some like GSG are made in German. We have never had one crack rotor.Then again we use state of the air CNC and don't drill our holes overly big. Also our rotors come stamped on the hub GSG so not be confused with a cheaper brand. But to answer your question it depends on the type of driving you do. Both are good.
    DUH! an Audi
    los angeles, CA
    Re: Rotor?
    in ancient times, and sometimes today...drilled rotors would crack when over heating. I remember hearing that at one time brembo rotors would crack from the back of the rotor not very visible and was very dangerous.
    If you get low quality rotors that are drilled, be very careful if you plan on tracking your car, but for the city I would highly doubt your rotors would get that hot for it crack unless you run over a large puddle after doing some spirited driving.
    slotted rotors, have a better reputation for not cracking.
    I personally like cross drilled/slotted and never had a problem and I cheaped out and went with some ebay rotors...it could just be your luck or maybe I lucked out with good quality.
    Once, my rotors go out GSG will have a phone call =D
    Feb 16 2006
    NY/FL
    Re: Rotor?
    I have zimmerman cross drilled in the front now, but I guess I am going with the zimmerman slotted.
    Previous:
    Nov 01 2007
    B7 A4 2.0TQT
    PA
    Re: Rotor?
    I think dimpled and slotted are good and sturdy
