Results 1 to 6 of 6
    Senior Member Two Rings Menlo S4's Avatar
    Aug 27 2008
    Bay Area
    Speaking of wipers...
    OK, I searched (maybe poorly), but I couldn't find the answer to:
    How do I get the nozzle to spray washer fluid past the driver's side wind deflector? I'm thinking of just using a toothpick or some other long, slender tool to redirect it manually, but I thought I'd run it by you'all first.
    Registered Member Two Rings
    Jan 14 2008
    Re: Speaking of wipers...
    I had to redirect mine manually, I think I used a jumbo paper clip. A toothpick might break so just try to find anything thin and strong. You will need to adjust a few times because every bit you move it drastically changes the spray path.
    Aug 27 2008
    Bay Area
    I'll try that, thanks.
    I wanted to make sure, just in case someone said OMFG you'll break it.
    Veteran Member Four Rings Beelzeebub's Avatar
    Oct 08 2008
    B7 S4
    i would suggest using a needle than a paper clip
    Account Terminated Four Rings
    Jun 02 2008
    2007 S4 MT6; B8 A4 2.0T Avant
    Toronto, Ontario, Canada
    just wondering...why?
    trying to understand. What's a wind deflector?
    thanks.
    Quote Originally Posted by Menlo S4 View Post
    Aug 27 2008
    Bay Area
    The wind deflectors are the black fins on the fronts of the wipers; they keep the wipers on the windshield when you're going, say, 80 in the rain. Without them, the airflow coming off the hood slips in between the wipers and the glass, and very little actual wiping occurs.
