just did my timing belt...(it was a lot easier than i thought, maybe a 3/10, if you can change your own oil and have basic mechanical knowledge you can do this) anyways how do you exactly bleed the coolant, i just squeeze the lower radiator hose(driver side) a couple of times and got a lot of air out that way. but on the diy timing belt it says "After the reservoir is relatively full you can take an Allen head and unscrew the little bolt on the metal coolant hardline that lies on top of the intake manifold" but i can't find this hardline.
TIA
