Results 1 to 11 of 11
    Veteran Member Three Rings sempaipaul's Avatar
    Dec 21 2007
    several Porsches
    Gaithersburg MD
    ashtray.... ohhhh gooshh..
    alright.. well i was able to get my ashtray out... and now it will not go back in :/ any pointers? is there any DIY on removing the ashtray? or also removing the AC control unit so i can get a broader arear/view to work with trying to put my ashtray back in?
    Thanks,
    Paul
    [email protected]
    Garage: 03' RS6 (FOR SALE); 16' 328i xDrive Wagon (FOR SALE); 13' X3 M-Sport; 05' Cayenne Turbo, 01' 911 Turbo
    Mar 28 2008
    Northern NJ
    Re: ashtray.... ohhhh gooshh..
    Things I am selling just PM me
    - RS4 Pedals (Automatic)
    - USP Lower Valence
    Veteran Member Three Rings BostonDriver's Avatar
    Sep 22 2004
    Massachusetts
    If you want to remove the ashtray from the A6, you must remove the radio and climate control first. See pics below.
    First, remove the radio head unit using proper radio removal keys and unplugging the wiring harnesses.
    Before you set aside the radio head unit, remove the radio keys by pressing down the spring tabs and pulling out the key. I have heard so many stories of stuck radio keys, and they are stuck because the unit has to be out of the dash to be removed properly.
    Remove the two bolts in the upper corner of the climate control unit (red circles below). Then, reach in from the top of the unit and push the unit out from behind.
    Unplug the multiple wire connectors, and set the unit aside.
    There are two tabs on the top hold of the ashtray the secure the assembly. Simply push down on these tabs (red circles below) push unit out from the rear. The ashtray is a very tight fit. Just keep pushing from the rear, and it will eventually free itself.
    Disconnect the wiring harness from the underside of the ashtray.
    Senior Member Two Rings mtxsho93's Avatar
    Sep 20 2008
    93 SHO, 02 A6 2.7T 6MT
    South Jersey
    This is an old thread but I wanted to add two things:
    1. Great post - Boston Driver. This helped me out a lot this afternoon.
    2. I found that it was impossible to remove the ashtray on my 6 speed without first removing the shifter surround. I used a plastic putty knife to pop the rear clips off of the surround to get it off. After that, the ash tray slid right out.
    Now to figure out why it was unplugged and how to properly route the wires...
    Thanks again!
    Ian
    Veteran Member Three Rings allroadstomtl's Avatar
    May 25 2009
    '12 Avant P+, '16 GSW
    Montreal
    where can one get the caddy / tray once its out?
    '12 A4 Avant P+, S-Line 3 Spoke, S-Line Stone Guards,
    Sep 20 2008
    South Jersey
    Quote Originally Posted by allroadstomtl View Post
    A replacement? genuineaudiparts, online auctions, shokan...I just ordered a new (used) ashtray assembly from shokan.
    Ian
    May 25 2009
    Montreal
    don't want the ashtray, but the insert
    Sep 20 2008
    South Jersey
    You can still get just that part from the places I listed.
    Ian
    Veteran Member Four Rings G Men 08's Avatar
    Feb 05 2008
    One trick pony at the time.
    Waterloo NY
    anyone have a picture of this ashtray delete?
    B6 A4 3.0-sold
    C5 A6 4.2-sold
    C4 A6 2.8-sold
    B5 S4 A few mods-SOLD thankfully!!
    MKIV Golf TDI- SOLD MPG were amazing but other than that...
    C5 allroad 2.7 auto
    Veteran Member Four Rings stef2.7t's Avatar
    Mar 22 2008
    '02 S6
    D'edmonton
    Isn't that ashtray delete only for the A3....if you look at the shifter trim it goes all the way to the ashtray...I dont think it will fit unless you trim the shifter surrounding.
    -Stefan-
    '02 S6 Atlas Grey
    '01 A6 2.7T MT Sport --- Sold
    '95 GTI 2.slo --- Sold
    Need Radio Keys, VAG-Com? PM Me, bring beer
    Jul 05 2009
    maine
    I would like to find a delete for the A6 but can only find one for the A3. If anyone knows where to purchase one, please let us know, thanks.
