Results 1 to 15 of 15
    Jul 11 2007
    Lakewood Cali
    Oil Pan Replacement whose done it?
    Hey real quick.
    Tomorrow ima dive right in and see exactly what i need to fix on my car its my first day off since i busted it.
    as far as i know i need to drop the subframe and then i can gain full access to my oil pan remove it then replace it...
    any idea how difficult it is or how llong it takes...
    speak from experience please.
    thanks!
    ill be away all day tomorrow cant wait
    Oct 29 2005
    10speed
    San Francisco, CA
    Re: Oil Pan Replacement whose done it?
    Quote Originally Posted by sixty40band View Post
    Hey real quick.
    thanks!
    I dont touch the subframe, undo the engine mounts, pull off the front end, and jack the engine up
    - Clint
    Jul 11 2007
    Lakewood Cali
    alright ill have to take look at that tomorrow. well see how much of a job i actually have
    Aug 26 2005
    Hey real quick.
    thanks!
    The engine should be supported from a cross beam from above, using cables or threaded rods and j hooks to suspend the engine from overhead.
    Feb 17 2005
    Sarasota, FL
    You dont have to pull the front clip, just remove the snub and its bracket from the block, remove the nuts on the motor mounts (keep the rear tranny mount bolted) and jack up the front of the motor. All you need to do is get it high enough to get the motor mounts out of the brackets and you have enough room to get the pan out.
    Jul 11 2007
    Lakewood Cali
    Quote Originally Posted by A4ringedONE8T View Post
    alrready pulled the front clip....
    omg how much of a job this is. its seriously the biggest pain in the ass i have ever dealt with as far as replacing a god damn oil pan...
    the motor is practically out.
    agh
    day 2 will be gin tomorrow.
    for all you guys that are low low, and daily drive your car. lift them now! you dont wanna go through what i just went through...
    so far the damage is a motor mount, the pan with like a 7 inch crack, and a few other things here and there... i rather snap another bumper before i have to go through with this again.
    agh! sorry just venting just had an entire day of hard work learning as i go. oh well saved me a lot of money
    pulling the pan tomorrow, doing timing belt and water pump :)
    Feb 17 2005
    Sarasota, FL
    Yea not sure why you pulled the front end as I said, if that were the case you could have dropped the subframe in 5 min, replaced the oil pan in about 30min, put it back together and gotten an alignment. Would have taken you 2 hrs and cost 100 bucks for an alignment
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Might need a 1/4" drive socket and rachet for the rear bolts on the oil pan. I believe they are hidden in the transmisison bellhousing if I remember correctly.
    -Doug
    Veteran Member Four Rings vdubstreets's Avatar
    Feb 20 2007
    02 a4, 97 Gti, 90 wrangler
    ct
    I have a engine support bracket so thats how i would of done it
    Veteran Member Four Rings Mark's Avatar
    1959 MGA 1600
    Chocolate Land, USA
    one of the reasons why I never lowered my car from the stock sport height . . . winters around here wouldn't allow it considering I drive it year round.
    what did you run over?
    -Mark
    1987 5000 CS TQ 2.2T I5 - No more . . .
    2002 Denim Blue A4 1.8TQMS - RIP
    2005 Ebony Black Pearl allroad 2.7TQMT6
    Kinda stock . . . Tinted, H-Sport Sways, HP-2 Calipers, RNS-E, Bluetooth, and iPod/Sirius combined
    Got Vag-Com?
    Jul 11 2007
    Lakewood Cali
    well i pulled the front end because i am at 72K on my car... so i figureed fuck it why not just do the timing belt and water pump. so thats why i did it this way. i think its been a HUGE pain in the ass but if i had to do it again i could do it easily.
    BTW front end takes about 30 min to take completly off. so i was perfectly fine with that
    Jul 11 2007
    Lakewood Cali
    hahah those 2 bolts were a pain in the ass for me to find! haha but finally found them :)
    Jul 11 2007
    Lakewood Cali
    Quote Originally Posted by Mark View Post
    yeah im def still going to be lowered but def not as low as i was.
    i hit a huge dip and just fuct everything up
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Quote Originally Posted by vdubstreets View Post
    That is the way to go.
    -Doug
    Veteran Member Four Rings RAVI's Avatar
    Jan 29 2006
    hella stock parts
    bay area-livermore-ca
    how low is your car and what susp. are you using?
    '02 Audi A4 1.8BTQM
