Results 1 to 2 of 2
Thread: Seizure!
    Veteran Member Four Rings quat's Avatar
    Apr 06 2007
    A4 Quattro 1.8T, H-D VRSCA
    Pittsburgh
    Seizure!
    I have a strong feeling one of my rear brake calipers is seized open. I've had problems with my emergency brake for a while. The stealer ship said it was the right rear that was seized open, I changed it, and still have a weak E-brake. Now the cables have snapped off of the handle.
    How can I tell which caliper is seized? Or if it was the cables?
    I know if they were seized closed i'd be going through pads and all that noise but since something is jammed open I don't have that problem.
    And I did search but every thread is about a caliper that is locked closed.
    -Ryan
    2002 1.8t Quattro
    Sep 03 2008
    '05 A4 1.8T
    Santa Barbara, CA
    Re: Seizure!
    Easiest way would be to try and stick a small flathead screwdriver in between your rear pad and rotor when car is parked and e-brake is on. whichever one can have the flathead fit between it is the seized one. This is just an educated guess mind you
