Results 1 to 4 of 4
    Apr 15 2007
    centerville
    fuel injectors leak
    last winter i had an issue with some of my injectors leaking and replaced all my o rings on them and know it sitts for 3 days and know they are leaking bad has any one else had this issue and how did you fix it. I am really glad you guys are smart but i am stumped
    Veteran Member Three Rings Unispeed's Avatar
    Feb 22 2007
    Earth
    Re: fuel injectors leak
    Quote Originally Posted by jareds4 View Post
    Did you clean any debree that may have been in the injector holes on the intake manifold? Also, did you put some oil on the o/rings before you slid the injectors in? I just revamped the injectors and have no such leaking...
    2015 Audi A4 2.0TFSI (GEN 3 engine) with DL501 transmission (GEN 2 tran.)
    (B9 A4 engine mated to an S4 transmission in a B8.5 chassis. )
    2000 S4 6spd stg 2+ (gone but not forgotten)
    Veteran Member Three Rings Ianxcom's Avatar
    Jul 30 2008
    Socal/Denver
    Is there a writeup anywhere to remove the fuel injectors? I think I have tracked down my misfires to a back injector and want to swap cylinders to see if that is the case.
    TIA!!!
    Veteran Member Four Rings infinkc's Avatar
    Feb 14 2004
    S Ã C, CÃ*
    did you make sure that you removed the old O rings if they were stuck in the rail?
