Results 1 to 9 of 9
Thread: A6 Hesitates
    Mar 28 2008
    Northern NJ
    A6 Hesitates
    Changed my spark plugs yesterday. Now the car seems to hesitate or studder now and then when accelerating. Doesnt happen all the time but alot. Anyone got thoughts? MAF problem?
    Things I am selling just PM me
    - RS4 Pedals (Automatic)
    - USP Lower Valence
    Veteran Member Four Rings oc-drop's Avatar
    Nov 20 2005
    B7 A4, C5 A6, 79 Camaro
    Newport to Rancho Sta Marg
    Re: A6 Hesitates
    What plugs did you use?
    ~Rick .. currently driving a B7 3.2 S-Line 6MT Dolphin Grey | DTMish | EuroGEAR CF Hood | H&R | sick halogen Ecodes | AZ Plate frame
    is it 4:20 yet?
    Mar 28 2008
    Northern NJ
    Re: A6 Hesitates
    Quote Originally Posted by oc-drop View Post
    OEM ones. I went to the Dealership for them
    - USP Lower Valence
    May 13 2008
    '03 A6 4.2,,93 90q, '87 4kq, 03 Allroad
    Las Vegas
    Re: A6 Hesitates
    Did you double check the gapping on the plugs? I had this problem before, and the gap was incorrect on the plugs
    Nov 20 2005
    Re: A6 Hesitates
    Quote Originally Posted by Retard Riot View Post
    part #? they should come pre gapped, unless they gave you wrong ones?
    is it 4:20 yet?
    Veteran Member Four Rings Stampy's Avatar
    Oct 02 2007
    A6, A8, X5, etc
    Windy City
    Re: A6 Hesitates
    Even though they should have been pre gapped, you should check. I have seen this exact situation before because the OEM stuff wasn't right. It wasn't on purpose or anything. When we found the problem, we checked the boxes they came in. Two of the bozed were bashed in, so they were probably dropped or stored wrong.
    Just a possibility....
    Village Idiot!!!
    (\__/)
    (")_(")
    lots of rings in my garage
    Veteran Member Four Rings twinsnailsS4's Avatar
    Richard Henry Dana Jr.
    Re: A6 Hesitates
    Could be a coilpack that's causing a misfire when you accelerate (actually, could be a number of other things too if it is a misfire). Do you hear any sounds when the stuttering happens? You can also try a post in your respective regional forum and see if someone with a VAG can pull up any codes.
    Current: B5 S4 Avant, F10 M5 (comp pkg), 14' Tundra (4x4), Lexus CT200h, BMW S1KRR
    Past: W212 E63, C6 A6 Avant, B5 and B7 S4 Sedans, FD RX7, a Civic Hybrid and 2 Beaters
    Mar 28 2008
    Northern NJ
    Re: A6 Hesitates
    Quote Originally Posted by twinsnailsS4 View Post
    I did Vag it no avail its sucha weird problem haha. How about the wires? Spark plug wires are the ones that came with the car. Its a 99 with 123k on the clock so i mean there prolly due haha oh and no sounds. It just feels like a studder almost as when you stall manual car but not quite as rough
    - USP Lower Valence
    Oct 30 2008
    Portugal
    Re: A6 Hesitates
    Has the same problem, and became even worse when car was running on lpg.
    Had to replace all the coils...Really wasn't in the mood for finding out which one was faulty.
