Results 1 to 20 of 20
    Senior Member Two Rings 02A4_B6's Avatar
    Dec 08 2005
    H-Sport 2007 RS4 Rear Sway
    was flippin through the search engine and found a thread regarding a h-sport rs4 sway that is 300% stiffer than the '07 oem rs4 sway. will this bar from h-sport fit our b6 a4? link provided
    http://www.tirerack.com/suspension/s...32R&perfCode=S
    02 A4 1.8T QUATTRO 5SPD
    87 COUPE GT 5SPD.....SOLD
    00 CIVIC SI 5SPD....TOTALED
    86 GTI 16V 5SPD...SOLD
    Forum Moderator Four Rings actlsub9's Avatar
    Jun 13 2005
    Audi
    Re: H-Sport 2007 RS4 Rear Sway
    Yes, it will fit.
    Greg - Moderator
    WWW.ACTLSUB9.COM
    Dec 08 2005
    not to be a pain but comparing the picture of the h-sport rs4 sway from the link i provided and the oem rs4 sway picture from ecs's website, the bars have a completely shape to them?
    Jun 13 2005
    Audi
    "While suspension products shipped will match your vehicle's specifications, photos shown only represent typical components."
    Greg - Moderator
    WWW.ACTLSUB9.COM
    Veteran Member Four Rings audikid66's Avatar
    Jun 13 2007
    Belmar,NJ
    what are the advantages to running this much bigger of a rear sway and what are the disadvantages? and if you put this in the back would you want to put and upgraded front rs4 sway also?
    Current car: Stage 3+ 2002 Audi allroad 6 speed
    Past cars:
    imola b6 avant 5spd/URS4 avant Big turbo aan/B7 RS4/k04 b5 Avant /BAT B5 Rally car/B6 Ultrasport/TT / multiple B5 A4 /5 speed ford f-150
    Registered User Four Rings Mike@PureMS's Avatar
    Jul 19 2007
    San Diego, CA
    Yes it fits. But I wouldn't recommend it by itself unless you've got some other suspension done. You can easily experience way to0 much oversteer and get you in serious trouble.
    Jun 13 2005
    Audi
    Quote Originally Posted by audikid66 View Post
    Front RS4 sway is the same size as A4 Sport and S4.
    Greg - Moderator
    WWW.ACTLSUB9.COM
    Jun 13 2007
    Belmar,NJ
    Quote Originally Posted by Mike@PureMS View Post
    but won't this help neutralize the extreme understeer that our cars have? i have h&r coil overs...what are the negatives to running this bar for me?
    Past cars:
    Jul 19 2007
    San Diego, CA
    This is like crushing an ant with a bulldozer.. It's so much more than you'd need to reduce some understeer, and quite frankly isn't the best way to reduce understeer. A properly setup suspension of springs and shocks is a much better approach. You reduce suspension travel, reduce dive, squat, and understeer, while still maintaining suspension independence.
    Mar 27 2005
    The Cold North
    since i am running these bars i will chime in. Unless you really need a stiff set of bars for track use or have worked with the suspension manufatuer to compensate for the stiffness of these bars DO NOT add them. They are very stiff. At the advise of STaSIS I actually had to increase the dampening on my suspension to compensate for these bars at the track. When heavily loaded at the track and quickly unloaded (chicane) they can break the rear end of the car loose. By increasing my dampening a tad it helped control that corner of the unloading suspenion some.
    They are overkill for the street and are not designed to be used on the softer A4 suspension. Even on the Rs4 H-Sport suggests them for track use and aggressive driving. The H-Sport S4 kit is a nice happy medium for street driven cars.
    2001 A4 1.8TQM (in pieces..)
    2020 Chevy AEV ZR2
    Veteran Member Three Rings tdmopar59's Avatar
    Jun 23 2008
    05 A4q 1.8t 6mt
    what about the h and r sway bars.... are they also a good quality aftermarket sway bar?
    05 1.8t 6mt | itg filter | bailey dv | UNI flash | USP front | e-codes | stay tuned
    help me buy more parts!! Any work you need in SE PA area on your car or with construction let me know!! (PM me)
    Aug 10 2008
    UK
    Could you suggest what an acceptable diameter rear sway bar would be to go to on an A4 USP Avant with stock 'sport' suspension? I don't want to make too stiff for the damping to cope with, I'm also am not tracking it at all. Fast road not dangerous road
    Think the stock USP bar is 18mm, I understand even going up 2mm is like double the stiffness.
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Quote Originally Posted by marc1 View Post
    Old thread. Lots of discussion: Clicky click
    Aug 10 2008
    UK
    Thanks Old Guy, some very interesting points you make in that thread.
    Active Member Four Rings Maverick's Avatar
    May 03 2007
    german
    heaven/hell
    just get the OEM RS4 sway, the H sport is overkill.
    I had a ride with EGT 18T's car, it felt very tight and firm. He had StaSIS tracksport.
    If you are running regular coilovers then you shouldn't run that bar. I will be scared that it can do damages and it will
    F80 M3 DCT|C250 Coupe|i3|16 RS7
    B6 A4 3.0 back to stock |B8 S4
    E46 M3 Heavily Modded IR/Black Cloth - track car
    E46 M3 TiAg/IR Moton/GC Track Ready - sold
    E92 M3 Melbourne Red/Black cloth/CF Roof - Exported
    E93 M3 AW/Black Sold
    E39 540iA Minor front end mods. Smashed|E39 540iA Aggressor - sold
    W126 1989 560SEC Totaled
    Bentley Continental GT Black/Black Mulliner Package - sold
    Porsche 944 NA - totaled
    Aug 10 2008
    UK
    Quote Originally Posted by Maverick View Post
    Maverick, do you mean don't runthe H-Sport bar with standard suspension or don't run the OEM RS4? Sorry mate, I got a bit confused then!
    I've got OEM USP (sport) suspension at present, thinking of moving to the OEM RS4 sway. Will this be ok?
    May 03 2007
    german
    heaven/hell
    OEM rs4 sway is good enough for you as of now. so I mean't don't run the H - Sport sway bar, RUN the OEM RS4 sway bar
    one day you might decide to take your car for auto - x, then it's time to get a track use coilover suspenion and the H sport RS4 sway bars.
    Veteran Member Four Rings OneBadAudi's Avatar
    Feb 25 2008
    02 A4 Quattro, 09 Yami YZ250f
    Cape May, NJ
    Think he means dont run the H-Sport with standard suspension..Do run the oem RS4 rear sway
    02 A4 Quattro stage 1+ (Giac Tuned)
    Siemens 380 injectors
    APR R1 DV
    K&N Air Filter
    5% tint
    STACKS boost gauge W/ Podi Column Mount
    Lip Spoiler
    Complete JL Audio sound system
    Aug 10 2008
    UK
    Cheers guys I get it now, thought that's what was being said. I'll be ordering the OEM RS4 tomorrow then
    Jul 19 2007
    San Diego, CA
    H-Sport's A4 setup is a great setup for daily driving even with factory sport suspension.
