Results 1 to 20 of 20
    Established Member Two Rings isramirez21's Avatar
    Aug 02 2008
    audi a4 2.8 1996
    IL USA
    Question camshaft position sensor (location) Where?
    Hello everyone.
    Do you guys know where are the Camshaft sensors located in an A4 2.8 1996?
    I know there are two, I have only found the one on the drivers side, but I don't see the one on the passenger side. Do you know where is located?
    A picture or some clues would help.
    Thanks so much
    Veteran Member Four Rings Beemer832's Avatar
    Sep 21 2004
    98.5 a4 1.8tqms
    KC MO
    Re: camshaft position sensor (location) Where?
    if I am correct, the cam position sensor is located on the intake cam shaft, which is the shaft closest to the intake manifold or inside of the V-angle.
    On one side of the engine its located in the front of the head, on the other side of the engine its located on the back of the engine. Very easy and simple to replace this piece. Two bolts, no seals or gaskets, unless your replacing the cam shaft seal.
    -josh
    -josh
    98 AEB 1.8t Laser Red
    EFR 6758 with VEMS standalone in the works.
    Aug 02 2008
    audi a4 2.8 1996
    IL USA
    Quote Originally Posted by Beemer832 View Post
    -josh
    Thanks for the reply
    Would you mind taking a picture of it? I don't seem to find it, I have looked around and cant see it.
    On the intake camshaft?! Do I have to unscrew anything in order to see it?
    Sorry for the dumb questions, but I'm new to all this.
    Sep 21 2004
    98.5 a4 1.8tqms
    KC MO
    actually i have a 4 cylinder turob engine so pictures arent going to help you :)
    i guess we need a v6 member to chime in. there could only be one cam sensor in reallity since all the cam shafts are tied together via the timing belt and cam chains.
    sorry i am not anymore help
    -josh
    -josh
    Aug 02 2008
    audi a4 2.8 1996
    IL USA
    -josh
    If I take a picture of the engine, would you point me where it is?
    Thanks you are helping me
    Sep 21 2004
    98.5 a4 1.8tqms
    KC MO
    sure thing.
    -josh
    -josh
    Aug 02 2008
    audi a4 2.8 1996
    IL USA
    sure thing.
    -josh
    Thanks
    Sep 21 2004
    98.5 a4 1.8tqms
    KC MO
    should be here..
    -josh
    Sep 21 2004
    98.5 a4 1.8tqms
    KC MO
    -josh
    Aug 02 2008
    audi a4 2.8 1996
    IL USA
    I should remove the plastic covers, huh! ( I just want to clean it because its giving me a check engine light. Also making the engine not to start)
    Thank you buddy
    Sep 21 2004
    98.5 a4 1.8tqms
    KC MO
    yea you will have to remove those timing belt covers. The cam shaft position sensor is bolted to the side of the head.
    kinda weird that you do have to remove those covers, mine is out in the open :)
    i love my four cylinder
    -josh
    -josh
    Aug 02 2008
    audi a4 2.8 1996
    IL USA
    -josh
    ha I bet you do. I wish I had one, but when I got it I didnt know the difference or anything.
    anyways is not that bad.
    Sep 21 2004
    98.5 a4 1.8tqms
    KC MO
    not at all. good luck getting er done. when you pull the sensor off, you will realize its just a cap with a wire and magnet/sensor. you will see the cutout on the piece attached to the cam shaft. make sure this is clean as well as the electric/magnet sensor on the cap piece.
    just be careful not to spray too much contact/electric cleaner on there.
    -josh
    -josh
    Aug 02 2008
    audi a4 2.8 1996
    IL USA
    -josh
    Should I spray the camshaft sensor also?! I was thinking just to spray the connectors, and clean the cam sensor.
    Thanks for the tips Josh
    Senior Member Three Rings urban96's Avatar
    Aug 09 2007
    Syracuse, NY
    pretty sure its on the drivers side head in the rear.
    had to unplug it the other day when i was replacing the valve cover gaskets
    remove the 3 screws that hold the coolant overflow in place and swing it out of the way and then u should be able to see down in there better
    -06 A4 2.0T
    -97 A4 1.8T
    Aug 02 2008
    audi a4 2.8 1996
    IL USA
    Quote Originally Posted by urban96 View Post
    I know about that one, thought. However is not that easy to remove because there is a black hose in the way, I was wondering if I could remove that hose?!
    Also there is another one which is on the front left of the engine, to see it I have to remove the timing belt plastic covers, which I cant because of the front belts that don't let me to take it off.
    Thanks
    Aug 09 2007
    Syracuse, NY
    the vaccume hose that connects to the cruise control? (i think thats what that thing is) yeah its easy to remove
    you sure theres also another one? i dont rememver seeing one over there when i did the timing belt but i could be wrong
    -06 A4 2.0T
    -97 A4 1.8T
    Aug 02 2008
    audi a4 2.8 1996
    IL USA
    yeah I'm sure There is another one.
    Today I took it to the shop to get a diagnostic. They told me that the timing belt needs to be replaced and the camshaft sensor too. The car has 135k miles.( its weird because its supposed to be replaced around 105k, but im not sure if the previous owner had it replaced.)
    One of the codes they got was that the timing belt jumped. I dont have any history of the car so I guess that's what I got to get fixed. They will charge me $350 for the camshaft sensor + $749 for the timing belt =$1099, does that sound right? (It's not a dealership)
    Feb 24 2004
    Minneapolis
    I have a 96 with the 2.8. There is only one CPS on the driver's side of the engine on the back. If the two camshafts are timed properly, you know the pass side camshaft if you know the driver's side. It's number 27 in this picture.
    The going price around here for a timing belt from an indy shop is closer to $800. I've done it myself. It's a day of wrenching, but you should rent the tools somewhere. Blau rents them here.
    Aug 02 2008
    audi a4 2.8 1996
    IL USA
    Quote Originally Posted by mtroxel View Post
    Thanks for the picture and the information. I didn't know I could rent tools to do it myself; sadly I have little experience with cars and have never done that, so I'm kinda afraid to break something else.
    Anyways Thanks for the help
