Results 1 to 9 of 9
    Registered Member Two Rings Sick_Boy's Avatar
    Oct 11 2008
    01 A4 1.8tqm
    St. Charles IL
    hooking up a forge 004
    ok i just received my 004 and i just want to make sure im going to hook it up right. so since its just a dump valve should i hook it up to the spot marked as 1? or 2? and im all stock right now but gunna be getting a ecu flash soon so is it ok to leave the yellow spring in set for 15-23psi or do i need to use the next one down? and is it ok to run a dump valve im not going to mess somthing up by leaving something unhooked am i? thanks
    Oct 11 2008
    01 A4 1.8tqm
    St. Charles IL
    Re: hooking up a forge 004
    hose 1 is off the intercooler line and 2 looks like its going to the air line doing into the turbo. im pretty sure it goes to 1 but just want to make sure
    Veteran Member Four Rings JumboBlack1.8's Avatar
    Sep 16 2006
    '98 528i
    Boston/West Hartford, CT
    You should be running a Diverter valve not a BOV unless you are BT and have a MAF-less file
    2000 Audi B5 S6 ** 4.2L 40v S6 6spd - http://www.audizine.com/forum/showth...n-s6-4-2L-swap
    Veteran Member Four Rings J-jizzle's Avatar
    Aug 28 2007
    Tools, Parts and the GTI beater
    Birmingham Alabama (Tennessee)
    Although I have a B6. I ran a yellow spring for a long time and I'm stock, I tried to run the green spring, but on cold start ups the car would shudder real bad cause the valve was opening under the higher ideal.
    But just recently I have been running the green spring after bypassing my n249 valve, cause the car seems not to like the yellow one anymore.
    Sep 16 2006
    '98 528i
    Do you mean the forge 007? the 004 is a BOV
    Veteran Member Four Rings Lazer Viking's Avatar
    Nov 06 2006
    garage ornaments
    southeastern pa
    it goes into the lower intercooler (from turbo outlet to cross pipe)
    the billet plug goes in the recirc hose (leads up to airbox)
    the 004 will be fine, it closes at idle so its works just fine
    sincerely, 004 owner
    -Nic
    My Car
    old junk new junk, red junk blue junk
    Registered Member Three Rings Rhinop21's Avatar
    Mar 04 2008
    West linn, Oregon
    For those who say run a dv, the 004 will work fine. Ive had the 004 on my 98 for almost a year now with no ill affects.
    http://i200.photobucket.com/albums/a.../dopeaudi3.jpg
    1998 A4 sold
    1995 Talon tsi awd. 6 bolt swap.
    Sep 16 2006
    '98 528i
    I'm running the 004 and turns out I know NOTHING about it, lol......it works great
    Feb 27 2005
    North Wales, PA
    if the 004 is closed at idle then you should be fine
