Results 1 to 6 of 6
    Senior Member Three Rings theboogieman1's Avatar
    Jan 08 2007
    02 Audi S4
    Pacifica, CA
    17884_EVAP Leak?
    anyone have any ideas? I just had my check valve replaced because one of the sides snapped. I was having misfires before but now those are gone and I have this "17884 EVAP Leak Detection Pump" code coming up everyday or two. I tried searching but there wasn't much on this code that I could find. Any ideas of what I should be looking around for, besides loose connections around that check valve? Thanks
    02' Black S4 6spd / JHM "Stage 3" / JHM "Solid" Shifter / VAST Stg. 3 Clutch and LW Flywheel / Vogtland GT's / 034 Track Density Motor Mounts/ AWE DTS / JHM FMIC / Hawk HPS Pads / H-sport sways / SSAutochrome TB Exhaust
    Veteran Member Four Rings Evilevo's Avatar
    May 26 2008
    2018 TTRS, 2014 Q5 TDI, 2020 Supra, 2022 F150, 2004 V70R
    MD
    Re: 17884_EVAP Leak?
    Have this same code.....
    Established Member Two Rings jesterekim's Avatar
    Aug 26 2007
    2001.5 Audi S4
    New York
    I think I might of had the same code. Make sure to click 3-4 times after filling up.
    Stage 2 | Brilliant Black | 6-speed
    GIAC X
    APR Stealth Catback
    APR Bi-Pipe
    Pro DFI Boost Gauge
    Jun 14 2007
    2000 S4
    Connecticut
    you have to check the evap lines that run from the motor to the back of the car... if you get under your car wrapping around near your exhaust by the gas tank there are some lines that are pretty hard and there are like 2 or 3 side by side running the length of the car. check for any tears in those lines.... also they lead into a black covered canister if you take the 3 screws/bolts whatever they are down there out you can see where the lines end up and make sure nothing has slipped off... if you cant find the lines near the back of the car go to the pass side and about 1-1.5 feet in you will see the lines there sometimes its easier to look there for them. make sure all your check valves are in tact as well on the pass side of the motor
    Veteran Member Four Rings S4-ORCE's Avatar
    Apr 16 2007
    01.5' S4 ASP Tuned
    Long Island
    2nd, Sometimes the exhaust clamps puncture the lines in the rear. I've experienced it personally. Check those lines.
    Jan 08 2007
    02 Audi S4
    Pacifica, CA
    Awesome, thanks man. I'm hoping I can get done with my work tonight so I can go an check that out. It's more than likely the case cause I've had this rattle coming from my brakes in the back and I've had people up there pounding around trying to find the source. They probably knocked something loose. Thanks again!
