Results 1 to 6 of 6
    Veteran Member Three Rings rzundel's Avatar
    Sep 20 2008
    Ferrari Challenge Stradale, Maserati GranTurismo S, Range Rover HSE, Porsche Panamera
    Westlake Village, CA
    What's the noise on my S4?
    I recently purchased a 2005 B6 S4. If I make a sharp turn from starting position, I hear a noise that sounds like a humming or vibration noise coming from what apprears to be my front drive train. Is this a standard sound with the quattro system or do I have another problem to worry about? The sounds only happens when I make a sharp turn and not when going in a straight line.
    Senior Member Two Rings B6_Rakete's Avatar
    Apr 17 2008
    '04 S4 Avant 6sp, '06 330i 6sp
    Re: What's the noise on my S4?
    Quote Originally Posted by rzundel View Post
    If you only hear the sound under a lot of steering lock -and- when you've got your foot on the gas (even lightly) it's most likely the Quattro system binding up a bit. It's normal.
    However, if you hear the sound when the car is not under power/clutch in, we may be talking about something else.
    Veteran Member Four Rings S4DTM's Avatar
    May 26 2008
    '12 TTRS, '01 S4 Full 3.0L Racecar
    Moraga, CA
    Sounds like the power steering, nothing to worry about if that's the case, just try to avoid turning the wheel all the way when you're not moving since it's not great for the car.
    [COLOR="red"]l FRRG Northern Ring President l
    '17 Alfa Romeo Guila Quadrifoglio
    '01 S4 Racecar "Giggles" - Sponsored by 034Motorsport
    Four Rings Racing
    Gone but Never Forgotten:
    '07 S4 DTM
    ->'12 TTRS - Phantom, Titanium, CF Mirrors, Sport Exhaust, Tech, Butt Warmers, Tint and Clear Bra, APR Stage 1, 034 Midpipes, AWE Boost Gauge
    Sep 20 2008
    Quote Originally Posted by B6_Rakete View Post
    I should mention that I have "tip" and the steering doesn't have to be in lock postion but when simply making a turn. Yes, the noise is heard only under acceleration (slight), not at rest.
    Jul 23 2007
    Central Coast, CA
    If you pop it into neutral while making a low-speed turn under light load and the noise/vibration stops, it's the Torsen (center) differential. Many seem to think that some level of this is "normal" and acceptable. Prior to my current S4, I've owned several Audi quattros and driven many others....from A3 to Q7....and none of them exhibited this problem. The noise was so severe in my S4, I had the dealer change out the Torsen unit (under warranty) and the noise & vibration were substantially reduced but not completely eliminated. I'll be seeing the service manager about this again before my warranty expires.
    Senior Member Two Rings Menlo S4's Avatar
    Aug 27 2008
    Bay Area
    I was hearing this same kind of sound when I was turning the wheel to the left -- it turned out to be the right wheel hub and bearings. The problem was solved by replacing those parts.
