I searched and didn't see anything out there regarding this, so I figured I do a write-up.
This is a very easy process and is also pretty cheap. I ended up spending about 5 minutes on each tip and I don't think the previous owner ever cleaned them. So it was about 3 years and 24,000 miles worth of wear.
Products Needed:
- Steel Wool (Not an SOS pad)
- Flitz Steel Polish (This is what made it really easy)
- Old Micro-Fiber or Rag
- Latex or Rubber gloves (optional)
- Empty Bucket (optional)
You can pick up Steel Wool at almost any hardware store and latex/rubber gloves at your local Rite Aid or Walgreens. I'm not sure where to pick up Flitz at as we just had it in our garage. My best guess would be a hardware store like Home Depot or Ace.
Procedure:
1. Put on your gloves if you're going to use them. If you choose not to, then your hands will be beyond dirty and it's a PIA to clean them.
2. Set your bucket on the ground next to your first exhaust tip upside down so you have a seat.
3. Pull about a nickel sized piece of steel wool and dip a portion of it into the Flitz container. You do not want a lot of Flitz. It's one of those few products where less is more.
4. Then just rub your exhaust tips with the steel wool. You will start to see the grime and baked on crap come off. If your piece of steel wool gets too broken down or dirty tear off another nickel sized piece and dip it in the Flitz. I ended up using two pieces, one for each tip.
5. Every once in a while I wiped down the exhaust tip with my old Micro-Fiber cloth to really check my progress. I wiped them down again when I was done to remove all the loose grime and dirt.
I hope someone finds this useful and good luck!
Also, I have the stock exhaust tips. I do not know if this process will work on aftermarket exhaust tips. Especially the diamond black ones that are quite popular.
Pictures:
Before:
After:
Progress:
*I am in no way responsible for any damage/harm you cause to your car or yourself by following this write-up. This process worked well for me and may need to be altered to suite your needs.
