Results 1 to 26 of 26
    Registered Member Three Rings ILikeBigBrakes's Avatar
    Sep 27 2008
    2002 Audi A4 1.8 Q&A
    Orlando, FL
    Transmission Feels Like a Race Car?
    Haha title is a little extreme sorry but wondering......How come when I shift it into drive or when it shifts down to second it kind of slams the gear? It feels like my 04 GTO when I had the transmission pressure up on the auto tranny. I have been reading up but cant figure out whether it has mounts maybe or some type of modification. I probably need to get under the car and do some looking around but does someone have a link or some insight they can give. The last thing I want is the transmission to fall out from underneath the car haha. Thanks in advance.
    Active Member Four Rings Maverick's Avatar
    May 03 2007
    german
    heaven/hell
    Re: Transmission Feels Like a Race Car?
    your tranny oil is due for a change.
    F80 M3 DCT|C250 Coupe|i3|16 RS7
    B6 A4 3.0 back to stock |B8 S4
    E46 M3 Heavily Modded IR/Black Cloth - track car
    E46 M3 TiAg/IR Moton/GC Track Ready - sold
    E92 M3 Melbourne Red/Black cloth/CF Roof - Exported
    E93 M3 AW/Black Sold
    E39 540iA Minor front end mods. Smashed|E39 540iA Aggressor - sold
    W126 1989 560SEC Totaled
    Bentley Continental GT Black/Black Mulliner Package - sold
    Porsche 944 NA - totaled
    Sep 27 2008
    Orlando, FL
    That was in the back of my mind, is there a good fluid everyone uses. I will search on this but post if you have a recommendation.
    Jul 09 2007
    01 A6 4.2 QUATTRO
    Portland, OR
    yeah try getting a trans service done, hopefully you dont have some clutch packs in there with some wear and the play is out of tolerance, that will cause excessive fill times and a slam into gear, but i havnt really heard that about audi transmissions being an issue, probably just needs a fluid and filter change
    May 03 2007
    german
    heaven/hell
    Quote Originally Posted by ILikeBigBrakes View Post
    flush the tranny and put in OEM fuild.
    Sep 27 2008
    Orlando, FL
    Ok, I need to look into steps for doing this on my own and getting it done. I rather not have to replace an audi trans.
    Sep 27 2008
    Orlando, FL
    While Im doing the fluid and filter change anything else I need from ECS tuning... magnetic drain plug.... gasket kit?
    May 03 2007
    german
    heaven/hell
    that I dont know, I didnt DIY
    Sep 27 2008
    Orlando, FL
    I probably wont either Im lazy but I can supply the parts and my buddy can do it at his shop cheap,
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    The stock plug should already be magnetic....plus the ECS plug is known for stripping (when removing)
    -Sami-
    Sep 27 2008
    Orlando, FL
    Good to know, will skip on that probably just grab the trans fluid and the filter and gasket kit.
    Veteran Member Four Rings downhillracer's Avatar
    Aug 20 2007
    97 Jeep Wrangler
    Costa Mesa / Mammoth Lakes
    Unfortunately I would recommend the stealership. They run a test on you fluid which checks the condition of your tranny. If they see brass, steel, clutch material they will let you know. Also they will change the filter too. I always like the diy but I love the fact that they test the fluid!
    Sep 27 2008
    Orlando, FL
    Oh really? Hmm with the way it feels driving it might be worth the test on the tranny then.
    Aug 26 2005
    What trans, 5 speed tip or CVT?
    Sep 27 2008
    Orlando, FL
    Its the Tip
    Aug 26 2005
    If it's a 5 speed tip, you can use Pentosin ATF-1, full synthetic and on the ZF approved fluids list, or the OEM fluid. If it's a CVT, use only the OEM fluid from the dealership.
    Senior Member Three Rings TverRus69's Avatar
    Sep 02 2008
    98.5 2.8 A4 QM
    NYC, Penn State, Tver Russia
    i still say look at the mounts. If you're slamming into gear when you put it in D that means your engine is pretty much trying to rotate and due to the fact that the mounts have gone bad, the block is able to turn a little. The fact that this also happens when you shift into second, is an indication of how much the mounts are worn. You can check the fluids first, but i almost guarantee that its the mounts. Search the threads for an explanation on how to determine which ones are worn. Also for a visual check just pop the hood, have somebody shift into drive and see if the engine "jumps" - then go by that.
    Sep 27 2008
    Orlando, FL
    Ok these are good starting points thanks so far, I will probably do the fluids just because it cant hurt and start looking into mounts.
    Veteran Member Three Rings Trev's Avatar
    Nov 25 2007
    b6 a4tq, 95 Eagle Talon (Rip)
    British Columbia, Canada
    If your doing it your self or getting your budy to do it, you will need vag-com.
    When filling up the trans with the fresh fluid you need to monitor the fluid temp with the vag-com in order to get the proper fill level.
    Sep 27 2008
    Orlando, FL
    Haha well that right there might warrant just going to the dealership, didnt know Id have to buy that to do it. Of course, it seems that the Vag-com system is a must for our cars, seems everyone here runs it.
    Nov 25 2007
    If you plan to be doing any moding to your car than this should be your first mod.
    Sep 27 2008
    Orlando, FL
    Yea I do and I bought the car with mods also so this will probably be important. They seem to have different models and packages on the vag-com website what is the most popular one?
    Veteran Member Four Rings 04QuattroTurbo's Avatar
    Jun 15 2008
    Fairfield, CA
    Sorry guys, I'm a little confused, probably because I have a 6 spd manual tranny. My understanding is the the B6 A4 has 4 transmission options, correct me if I'm wrong.
    1. 5 Speed Manual Transmission
    2. 6 Speed Manual Transmission
    3. 6 Speed Automatic Tiptronic Transmission
    4. Multitronic, CVT with simulated 6 ratios transmission
    Did I get that right or was I totally in dream land?
    2004 (B6) Audi A4 Quattro 1.8L Turbo 6-Spd Man
    Premium Pkg, Cold Weather Pkg, Ultra Sport Pkg, Lighting Pkg, Sirius Satellite. Dolphin Grey
    APR Stage I, K&N 33-2209 Drop-in filter, Apr Snub mount, RS4 pedals
    VIN Decoded: http://www.motoverse.com/tools/vinDe...LC68E84A219972
    USP Member 110
    WANTED: Roof Spoiler, PM me with Offers.
    Sep 27 2008
    Orlando, FL
    Still interested in hearing feedback on which vag-com package would be the ideal to go with? Thanks!
    Veteran Member Four Rings Charlescrs6's Avatar
    Sep 28 2008
    Boston, MA
    could also be the torque converter i guess... mine just went bad and thats 3k out the door, my only symptoms were it took like 3 seconds for it to get into gear, R or D from Park, and it always slammed into 3rd gear
    Current: ISO RS4
    Past: E46 M3 Convertible 6MT, B6 A4 1.8TQM Ultrasport, B6 A4 3.0Q
    Sep 27 2008
    Orlando, FL
    Hmm its weird it goes immediately into gear and drives perfect... no leaks I can see either.
