Results 1 to 7 of 7
    Veteran Member Three Rings 2k1audiS4's Avatar
    Oct 30 2007
    Pasadena, MD
    PLEASE HELP!!!!!!!!!!!!I think I screwed my motor up.(PICS)
    What happens if you do a pressure test with this connected? It goes into the y pipe, im not exactly sure what it does but I remembered after the test that your supposed to disconnect it. When I drove my car after the test tons of white smoke came out for about 3 or 4 minutes then went away. I still have full boost and the car did not miss or run different but there was a lot of white smoke for a few minutes. The car seemed to loose a little power(could be my imagination) but i am still getting full boost. Did I do any damage. What could this be? Please help I am panicking right now.
    2001.5 S4 Silver 6MT......GIAC X, APR Bi-Pipe, FMIC, "Custom" UUC VM1, RS4 Clutch, APR R1 DV's, AWE DTS, K&N, Eibach pro kit, D3........SOLD
    2000 S4 Black 6MT.....Stock........SOLD
    2000 A6 2.7T 6MT.....Stock..... SOLD
    2001 S4 Sport Black 6MT.....Stock......SOLD
    2001.5 S4 Santorin 6MT....Stg2.....SOLD
    2001.5 S4 Sport Santorin 6MT....Stg2....SOLD
    2001 S4 Sport Silver 6MT.....Stg1....ACCIDENT THEN SOLD
    Oct 30 2007
    Pasadena, MD
    Re: PLEASE HELP!!!!!!!!!!!!I think I screwed my motor up.(PICS)
    I figured out that it is the PCV valve (positive crankcase ventilation valve). But I still need help as to if i could have screwed anything up.
    Thanks,
    Rob
    Oct 29 2005
    10speed
    San Francisco, CA
    nah man, there was probably oil in there and u blew it into the motor
    - Clint
    Oct 31 2005
    Ashburn
    Quote Originally Posted by 2k1audiS4 View Post
    Just remember for next time that comes off and also the oil cap comes off as well.
    - Instagram: @Sinister_rs5-
    Veteran Member Four Rings S4-ORCE's Avatar
    Apr 16 2007
    01.5' S4 ASP Tuned
    Long Island
    You're fine. Don't sweat it, when you dont remove that theres some oil in there that gets blown thru and goes out the exhaust. It will clear up.
    Oct 30 2007
    Pasadena, MD
    Alright good. I was real worried there for a minute. All I kept thinking was "lots of white smoke either means blown turbo or head gasket". Thanks everyone. Now I can relax and go watch the game.
    Veteran Member Four Rings gointoscott's Avatar
    Jan 26 2006
    2001 Audi S4
    Milwaukee, WI
    Your screwed one of your turbo's up by blowing one of the gaskets on the turbo from not disconnecting the pcv.
    JK Yep your ok. I've seen this done before and you just need to burn the oil out. But I hear you. I bet your heart skipped a few beats when you saw all that smoke coming out the back of the car.
    Make sure and take the oil cover off and cap off the pcv next time!
    Original K03's, Ecodes, H&R Coilovers, Inmotion Chip/MBC, Piggies
