Results 1 to 24 of 24
Thread: After debadge
    Jan 08 2008
    After debadge
    i just debadged my A4, and when you look at it you can see a "ghost image" of the letters. It looks almost as if they put on the clearcoat AFTER they put on the letters. Is this normal? When i run my hand along it, it doesn't feel smooth either, but i'm pretty sure it's not the glue either because i took it all off with goo gone and it looks like the unevenness is from the clearcoat.
    Veteran Member Three Rings Larson7.62's Avatar
    May 22 2008
    2008 Audi A4
    Bellevue, WA
    Re: After debadge
    I wonder if clay barring would help?
    Brilliant Black 2008 Audi A4 6MT S-Line/APR Tuned/Carbonio Intake
    Veteran Member Four Rings muffinman's Avatar
    Jul 01 2007
    Ask, USA
    Re: After debadge
    try mild polish + a couple coats of wax.. should help a bit
    edit: actually, might wanna confirm whether there's clearcoat or not.. can't imagine using polish on straight paint would be good for the car
    2015 Audi S3 Prestige with Performance Package - on order
    2015 Audi Q3
    2009 Audi S5 Coupe - Tiptronic, B&O, Technology Package, Navigation, Carbon Atlas
    2009 BMW 328i
    2007 Audi A4
    FS: CPO 2009 Audi S5 - Tiptronic - Warranty - Seattle, WA
    Jan 08 2008
    Re: After debadge
    thanks guys, will try clay, and if that does work polish
    Veteran Member Four Rings EMAXX's Avatar
    Jul 12 2008
    Re: After debadge
    With an 06, you shouldn't have to worry about the badge leaving a mark.
    Hopefully the clay will work for you.
    2015 Audi S4 Prem+ Sepang Blue/Magma, 6MT, Eurocode Alu Kreuz, Eurocode Transmission Brace, Eurocode Sway Bars and Endlinks, RocEuro Intake, AWE Touring Exhaust
    May 03 2008
    06' B7A4 20T Non-Sline
    Monterey, CA, 93940
    Re: After debadge
    GOO GONE..then clay and wax :P
    Jan 06 2008
    Dacia Sandero
    Arizona
    Re: After debadge
    ^ thats all you need. goo, wash, wax - i didnt need to claybar mine
    B8.5 []S5 . BBS . H&R . AWE . DEVAL . Stėrn . 034 . OEM+
    Nov 01 2007
    B7 A4 2.0TQT
    PA
    Re: After debadge
    GOO GONE will solve all your problems....at least it has solved mine
    Veteran Member Three Rings ItsThat2.0T's Avatar
    Oct 28 2007
    Rhode Island
    Re: After debadge
    My 97 Accord didn't leave a mark when I took the badges off, can't imagine why you would.
    '07 Quattro A4 Brilliant Black
    | Premium Package | Carbonio CAI | 35% Tint | Trunk Lid Spoiler | REVO | VMR Vent Boost Gauge |
    2 Pedals.
    Veteran Member Three Rings jimmya4's Avatar
    Aug 21 2008
    A4 b7
    The OC/ Boulder, CO
    Re: After debadge
    goo gone with a rag then wash and then use a clay bar. mine didnt come off until i clayed it
    2005.5 Quartz grey A4 Quattro 6mt/ REVO stage II
    May 03 2008
    Monterey, CA, 93940
    Re: After debadge
    Quote Originally Posted by ItsThat2.0T View Post
    Comments like these make me laugh, Of course some arent going to have marks, but others do. I had marks and mine was an 06, the badges were on for a good yr and half before i took them off. Even with my 04 GTI i had to goo gone it...
    DUH! an Audi
    los angeles, CA
    Re: After debadge
    polish it
    Oct 17 2008
    2006 A4 S-Line 2.0T Tiptronic
    Ohio
    Re: After debadge
    sorry for the late post... did you just peel them off?
    or use a hairdryer to soften the glue? i hate the look of the letters, so hard to clean in the middles unless u get a q-tip or something. want to pull them all off ;)
    Jan 06 2008
    Dacia Sandero
    Arizona
    Re: After debadge
    Quote Originally Posted by Jason-B7 View Post
    Heat with a hair dryer or heat gun to soften the glue, then use a piece of strong fishing line or even dental floss to pop the badges off. Once off, use GOO GONE to take off all remaining residue.
    Then wash, dry and POLISH the area where the letters were to remove the ghosts.
    Registered Member Two Rings
    Apr 03 2007
    Boston
    Re: After debadge
    Probably took it off too late.
    Is it residual glue or faded paint?
    Veteran Member Four Rings AvantNoir's Avatar
    May 22 2007
    Santa Monica CA
    Re: After debadge
    After glue is removed. Rubbing compound, polishing compound, and lots of wax, If you have an orbital buffer, all the better. The ghosting is in the clearcoat.
    2005 USP A4 Avant 1.8T Follow me on instagram @m27autowerks
    Senior Member Three Rings jaynyce's Avatar
    Nov 12 2005
    05 Audi A4 Quattro USP
    Re: After debadge
    I had that same problem. Try using 3M rubbing compound, It works great believe me.
    May 22 2007
    Santa Monica CA
    Re: After debadge
    Quote Originally Posted by jaynyce View Post
    3m Professional line is the best.
    Established Member Two Rings Dcting's Avatar
    Mar 25 2008
    Forest Hills, NY
    Re: After debadge
    Had the same problem when I debadged my old jetta. Goo gone didnt work, had to get a detailer to buff it out with very light wetsanding... Hope this helps good luck.
    -DT
    Veteran Member Four Rings ggg20t's Avatar
    Sep 18 2008
    Pittsburgh, PA
    Re: After debadge
    I just took mine off last night and have the damn ghost letters. I used the hair dryer, dental floss, goo gone, washed it, waxed it and i still have them pretty bad. How do you apply the rubbing compound safely without scratching the hell out of it??
    Registered Member Two Rings (o)o)o)o)'s Avatar
    Oct 19 2008
    '08 B7 A4, '07 BMW 328i
    Re: After debadge
    goo gone.
    Veteran Member Four Rings nick71692's Avatar
    Jan 16 2008
    2010 S4, 2005 A4 USP, 2008 BMW 650I Conv. Sport, 2013 Jetta GLI
    Ohio and GTA
    Re: After debadge
    go to autozone and buy something called sticker shock, apply it a couple times and your good, plus its cheaper than goo gone.
    2005 Dolphin Grey USP
    USP CLUB MEMBER #210
    2008 Ibis White S-Line A4 6mt, Stasis Exhaust (Gone)
    2010: S4, Ibis White, S-Tronic (Gone)
    2011 MKVI GTI 4 Door, Carbon, DSG (Gone)
    2012 S4, Monsoon Gray, 6MT (Gone)
    2014 S4, Glacier White - fully loaded (Gone)
    2019 S4, Glacier White - Prestige
    Nov 12 2005
    Re: After debadge
    Quote Originally Posted by ggg20t View Post
    make sure the surface is well cleaned, and apply the compound with your hand in circular motion and wipe it off after like 12 rounds with your hand. but the compound should definitely do the trick. also if you still have the paste from the emblems, then use prep-sol it will rub off
    Veteran Member Three Rings Tru NY Player's Avatar
    Apr 27 2007
    TIME MACHINE
    Tha M.I.A.
    Re: After debadge
    f@#! it..Ghost ride that $hit
    'Leave sooner, drive slower, live longer.'
