After having severe issues with an annoying rattle coming from my passenger side control arms, (video: http://s45.photobucket.com/albums/f9...t=MOV00663.flv) i broke down and bought a set of these from Blauparts: http://www.blauparts.com/proddetail....1101%2D02%2D1A
I got a couple quotes on the install, and they were all around the $500 range. I could have easily have paid to have the work done, but after reading a couple DIY's on the install, i decided to tackle it myself.
I was apprehensive about doing it, but thought it would be a good learning experience. I did one side a day as to not rush the job and possibly eff something up. The first side took me about 8 hours; i took my time and learned along the way. The second side took me right around 4 1/2 hours as by then i knew what i was doing and it obviously made the second time around much easier.
So i just thought i'd share some......okay, a lot of pics of my experience - enjoy!
Breaking loose the CV joint/axle nut (sexy legs FTW!!):
TRE removed (decided not to change these out as they were just replaced recently)
I'm coming for you, beotch!!
Pinch-bolt out (slid right out) and upper arms detached:
Disconnecting coilover from lower arm:
Pushing out the CV joint from the knuckle:
Disconnecting lower arms from the knuckle:
Don't forget the swaybar link, check
