Results 1 to 3 of 3
    Veteran Member Four Rings scottykenneth's Avatar
    Dec 01 2006
    S .NJ
    E brake jammed or stuck??( rear brakes)
    went to pull out of the driveway(driveway on slight slant)- e brake down and in neutral-- not rolling out like I always do-- gave some gas not rolling-- then more gas and kinda popped out from the rear brakes-- felt like the e brake was still on but the handle was down-- def from the rear--
    - the car was sitting for two days and i did wash the wheels-- maybe little rust on the pistons-calipers?- got stuck?>
    any input would be great..
    thanks
    Instagram:ScottyKenneth
    ScottyKenneth's Build Thread
    PRESENT : White 2018 Porsche 911 GT3 ( manual) / 2018 Jeep Grand Cherokee Altitude
    PAST : 2018 White Carrera 911 GTS / 2018 GT Silver Carrera 911 GTS / 2016 Porsche Cayman GT4 / 2015 []RS5 / 2014 S5 / 2010 A5 SLINE / 2007 A4 SLINE / 2001 A4 /
    Registered Member Two Rings dubfreak75's Avatar
    Aug 14 2008
    '06 A4 B7, '04 Tahoe
    Spokane Washington
    Re: E brake jammed or stuck??( rear brakes)
    You might want to pull your rear wheels and check to make sure the rotors are not cracked. I had this happen to a 2000 Golf before. If they are you could do a lot more damage in the very near future. Good luck!
    Dec 01 2006
    S .NJ
    thanks-- yeah just dropped off the ride to get the new exhaust one and coils-- I also said to look at this-
