    Veteran Member Three Rings Grangalan's Avatar
    Sep 27 2007
    Stage III 2001.5 S4
    Clearwater, FL
    Meh my hood latch cable popped off.. how do i fix?
    I guess when the engine was put back in the hood latch cable wasnt fastenend all the way so now my latch has lots of play and the hood wont open... Any ideas what do to to pop my hood so i can fix my problem
    Edit: FIXED
    Okay found the hood latch underneath, its a little hidden. Basically shine a light between engine and cooling fan. Right above the cooling fan you will see a black plug, that's the hood sensor. RIGHT ABOVE that plug is a metal pin which visually is hard to see. thats your hood latch release, i used a big pry bar and pushed towards the drivers side.. Voila hood open.
    --Black 2001.5 -S4- 10secS4 Tuned
    Sep 27 2007
    Stage III 2001.5 S4
    Clearwater, FL
    Re: Meh my hood latch cable popped off.. how do i fix?
    I did some searching but still no luck, i can see the hood latch cable , it's hitting my fan when i spin it.
    Veteran Member Four Rings RolledMySTi's Avatar
    Jul 06 2007
    2001 S4 Sedan Laser Red
    San Jose, CA
    I had this happen to me. You need to pop the hood latch from underneath the car. I went to Home Depot and got a thin 3ft peace of metal, bent the end of it a little and popped the latch from underneath. You have to press decently hard to get it to pop and make sure you are pressing on the right part. It's pretty easy once you are pushing the right spot.
    01 Laser Red S4 Stage 3 | Vast Fueling | Clutchnet 6 Puck Disk with RS4 PP | APR Downpipes | Aluminum Flywheel | Neuspeed Exhaust | SRM Side Mounts | ECS Pulley Kit | RS4 Airbox | UUC Short Shifter | ST Coilovers| Samcos | AWE DTS Bar | JHM Center Diff | 034 Track Motor Mounts + Street Trans Mounts | Apikol blue rear diff mount and bushings | Areomotive Fuel Pump | ECS 2.0T Coil Conversion | Hooked on Meth
    Sep 27 2007
    Stage III 2001.5 S4
    Clearwater, FL
    Quote Originally Posted by RolledMySTi View Post
    where underneath do i look, above the clutched fan area? i see the cable and ball joint and the end of the cable, it popped off and now hits the cooling fan. But where do i push and do i push up towards the hood or towards the drivers side?
    Jul 06 2007
    San Jose, CA
    There is part of the latch that hangs out that you have to push straight up. It helps if there is another b5 around for you to take a look at or I had a friend look on his and describe it over the phone.
